How can I convert an attribute block to Text or Mtext
I'm currently on the search for a .lsp that would convert an attribute block to text or mtext without the invisible attributes. For ex: If after entering every attribute (visible and invisible), the block shows "3-25L12," I'm looking for a .lsp to convert this block to a text or mtext showing "3-25L12."
All I can find right now are lisps that "Burst" the block and then convert all to Mtext.
I attached the attibute block I made to this message.
JTBWorld
What if you have different attributes values in multiple block instances? Do you want the text to be separate from the block?
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Basically, what I need is a to convert the final result of my attribute block to text. Doesn’t even need to be Mtext. It believe it would be easier if I could click on an attribute block, then write the .lsp command, press enter and have a line of text. I’d do one at a time. If there is a way to “Select all” similar attribute blocks and have them all convert to individual texts, even better.
Hopefully this answers your question 😊
JTBWorld
If you are willing to pay for the work we can create a command that converts one or many blocks. If interested please contact us
Jimmy Bergmark
Actually, I just found what I was looking for on lee-mac... The lisp is called upgraded burst.
Thanks for your help
