How can I check if a variable is Null with AutoLisp?
How can I check if a variable is Null with AutoLISP? I have tried a dozen different methods and nothing seems to work for this simple script.
What I am trying to do is see if variable "a" has a value and if it does not then prompt the user to assign it. Here are some of the methods I have tried so far...
(defun c:ZOINK ()
    (if (null (getvar a))
    (if (null a))
    (if (nil a))
    (if (= a nil))
    (if (/= a nil))
    (if (= a null))
    (if (/= a null))
        (setq a (getreal "\nEnter a Number : ")
         b (getreal "\nEnter Second Number : ")
Every single one returns with an AutoCAD message stating "AutoCAD variable setting rejected: "CMDECHO" nil". If I remove the conditional the script works as expected.
ВeekeeCZ
Are you talking about variables in general, or autocad's system variables? Because (getvar a) you can only use for 2nd ones.
Also, it difference between 0 and nil. The CMDECHO system variable accepts 0 or 1 values. You cannot assign nil to any system variables.
If a is a regular variable, there are many ways not to test if it's nil (= null).
(defun c:ZOINK ()
  (if (not a)
    (setq a (getreal "\nEnter a Number: ")
          b (getreal "\nEnter Second Number: "))))
Or very often we use OR.
(or a
These are also possible
(null a); (= nil a); (/= T a)
BUT compare to (zerop a) - This tests whether a is actual 0 (not nil).
ВeekeeCZ
@Anonymous wrote:
    (if (null (getvar a)) wrong; a has to be a name of system varible - (getvar "cmdecho"); also never nil, so usually (if (= (getvar "cmdecho") 0), or (zerop (getvar "cmdecho"))
    (if (null a)) good
    (if (nil a)) wrong, nil is a symbol
    (if (= a nil)) good
    (if (/= a nil)) good, but it the other way around
    (if (= a null)) wrong, null is the function, not a symbol
    (if (/= a null))  wrong, dtto
Kent1Cooper
    (if (null a)) ; get rid of extraneous )
    (if (nil a))
    (if (= a nil)) ; get rid of extraneous )
    (if (/= a nil))
    (if (= a null))
    (if (/= a null))
or, as already suggested:
(if (not a)
This one:
(if (/= a nil)
[without the extraneous ) ]
can be done with simply:
(if a
Kent Cooper, AIA
