This code requires selecting objects in the drawing, and I need to make it select all objects in the drawing and apply the rest of the code functionality to them:
(defun c:bmon (/
ss
mts
vl_mts
mask_on
mt
mt_dxf
leader
(setq ss (ssget '((0 . "MTEXT"))))
(setq mts (ssnamex ss))
(setq ss nil)
(setq mts (mapcar 'cadr mts))
(setq mts (vl-remove-if-not '(lambda (x) (eq (type x) 'ENAME)) mts))
(setq vl_mts (mapcar 'vlax-ename->vla-object mts))
(mapcar '(lambda (x) (vla-put-BackgroundFill x :vlax-true)) vl_mts)
(foreach mt mts
(setq mt_dxf (entget mt))
(setq mt_dxf (subst (cons 63 256) (assoc 63 mt_dxf) mt_dxf))
(setq mt_dxf (subst (cons 45 1.25) (assoc 45 mt_dxf) mt_dxf))
(setq mt_dxf (subst (cons 90 3) (assoc 90 mt_dxf) mt_dxf))
(entmod mt_dxf)
(if (assoc 330 mt_dxf)
(progn
(setq leader (cdr (assoc 330 mt_dxf)))
(vl-cmdf "_draworder" leader "" "_a" mt "")
