Highlight selected object
msarqui
Message 1 of 13
msarqui
Hello!
I found this routine here : http://www.cadtutor.net/forum/showthread.php?48458-Replace-Selected-Block-Or-Blocks-With-Another-Blo...
The routine is awesome, but I have a cosmetic issue. I noticed that it does not "highlight" the source block. It would be possible to upgrade it, in a way to have this traditional feature that indicate the source object has been selected?
(defun c:BRE (/ *error* blk f ss temp)
  ;; Replace multiple instances of selected blocks (can be different) with selected block
  ;; Size and Rotation will be taken from original block and original will be deleted
  ;; Required subroutines: AT:GetSel
  ;; Alan J. Thompson, 02.09.10
  (vl-load-com)
  (defun *error* (msg)
    (and f *AcadDoc* (vla-endundomark *AcadDoc*))
    (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
      (princ (strcat "\nError: " msg))
  (if
    (and
      (AT:GetSel
        entsel
        "\nSelect replacement block: "
        (lambda (x / e)
          (if
            (and
              (eq "INSERT" (cdr (assoc 0 (setq e (entget (car x))))))
              (/= 4 (logand (cdr (assoc 70 (tblsearch "BLOCK" (cdr (assoc 2 e))))) 4))
              (/= 4 (logand (cdr (assoc 70 (entget (tblobjname "LAYER" (cdr (assoc 8 e)))))) 4))
             (setq blk (vlax-ename->vla-object (car x)))
      (princ "\nSelect blocks to be repalced: ")
      (setq ss (ssget "_:L" '((0 . "INSERT"))))
     (progn
       (setq f (not (vla-startundomark
                      (cond (*AcadDoc*)
                            ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
       (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))
         (setq temp (vla-copy blk))
         (mapcar (function (lambda (p)
                             (vl-catch-all-apply
                               (function vlax-put-property)
                               (list temp p (vlax-get-property x p))
                 '(Insertionpoint Rotation XEffectiveScaleFactor YEffectiveScaleFactor
                   ZEffectiveScaleFactor
         (vla-delete x)
       (vla-delete ss)
       (*error* nil)
  (princ)
(defun AT:GetSel (meth msg fnc / ent good)
  ;; meth - selection method (entsel, nentsel, nentselp)
  ;; msg - message to display (nil for default)
  ;; fnc - optional function to apply to selected object
  ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
  ;; Alan J. Thompson, 05.25.10
  (setvar 'errno 0)
  (while (not good)
    (setq ent (meth (cond (msg)
                          ("\nSelect object: ")
    (cond
      ((vl-consp ent)
       (setq good (cond ((or (not fnc) (fnc ent)) ent)
                        ((prompt "\nInvalid object!"))
      ((eq (type ent) 'STR) (setq good ent))
      ((setq good (eq 52 (getvar 'errno))) nil)
      ((eq 7 (getvar 'errno)) (setq good (prompt "\nMissed, try again.")))
Thanks!
Replies (12)
Message 2 of 13
Kent1Cooper
The (redraw) function will do that.  If I'm getting the right entity name out of the special-purpose selection function [without studying that doo deeply], try adding this to highlight it before asking for Blocks to be replaced:
      (not (redraw (car x) 3))
Since (redraw) always returns nil, I wrapped it in a (not) function so it would return T instead, and therefore contribute appropriately to the (and) function that's underway at the time.
Oh, and you should probably do another (redraw) when it's done, with the 4 argument to un-highlight it.  Otherwise it will remain highlighted until the next Regen.
Kent Cooper, AIA
Message 3 of 13
msarqui
Hi Kent
It does not work
Error: bad argument type: lentityp nil
Message 4 of 13
Kent1Cooper
@msarqui wrote:
It does not work
That's the "if" in my second sentence -- I tried using (car x) because that's what was used to make a VLA object in this line a little above:
But I see that's internal to the calling of the selection function, so....  How about:
(not (redraw (car ent) 3))
Kent Cooper, AIA
Message 5 of 13
msarqui
I had the same error 😞
Message 6 of 13
Kent1Cooper
Another try:
(not (redraw (vlax-vla-object->ename blk) 3))
Kent Cooper, AIA
Message 7 of 13
msarqui
Perfect!!!!
I also put (not (redraw (vlax-vla-object->ename blk) 4)) at the end to un-highlight it. And it works very well.
Thanks Kent!
Message 8 of 13
Kent1Cooper
@msarqui wrote:
Perfect!!!!
Thanks Kent!
Good -- I should have delved a little deeper to begin with, and might have come up with the right approach sooner.
It doesn't hurt, but I expect there's no point in the (not) wrapper around the (redraw) function at the end.  It's needed earlier because it's within an (and) function and you don't want (redraw)'s nil return to spoil that, but assuming that where you're un-highlighting it you're no longer inside that (and) function, the (not) serves no purpose.
Kent Cooper, AIA
Message 9 of 13
msarqui
You are right. It also works without the "(not"
Thanks!
Message 10 of 13
3dwannab
I've a similar question. I want to grip highlight the new block afterward with something like:
(sssetfirst nil sset)
Also, the prompt for the new blocks doesn't appear for the:
Thanks.
Message 11 of 13
3dwannab
Thanks for this LISP Kent.
I hope you don't mind me posting my edit but I got it working.
I've added redraw to old block selection like this post, Error handling for redraw and sssetfirst newly created blocks.
Thanks again 🙂
(defun c:BK_Replace (/ *error* oldblk newblk f ss1 ss2)
;; EDIT by 3dwannab, 09.04.18 - Added redraw to old block selection, Error handling for redraw and sssetfirst newly created blocks.
;; Found at: http://www.cadtutor.net/forum/showthread.php?48458-Replace-Selected-Block-Or-Blocks-With-Another-Block
(vl-load-com)
(progn
(redraw (vlax-vla-object->ename oldblk) 4)
(if
(and
(AT:GetSel
entsel
"\nSelect NEW block: "
(lambda (x / e)
(if
(and
(setq oldblk (vlax-ename->vla-object (car x)))
(not (redraw (vlax-vla-object->ename oldblk) 3))
(princ "\nSelect OLD blocks to be replaced: ")
(setq ss1 (ssget "_:L" '((0 . "INSERT"))))
(progn
(cond (*AcadDoc*)
; Set ss2 to a null selection set:
(setq ss2 (ssadd))
(vlax-for x (setq ss1 (vla-get-activeselectionset *AcadDoc*))
(setq newblk (vla-copy oldblk))
(vl-catch-all-apply
(list newblk p (vlax-get-property x p))
; The following command adds the newblk entity to the selection set referenced by ss2:
(ssadd (vlax-vla-object->ename newblk) ss2)
(vla-delete x)
; Select ss2
(sssetfirst nil ss2)
(vla-delete ss1)
(*error* nil)
(princ)
(setvar 'errno 0)
(while (not good)
("\nSelect OLD blocks to be replaced: ")
(cond
((vl-consp ent)
Message 12 of 13
Kent1Cooper
The first one looks like it should work, provided the 'sset' variable [I don't see how you're setting that] contains a selection set  [not, for example, an entity name].
For your second one, if you're talking about the code at the top of the thread, the prompt is before  that, and unfortunately, (ssget) always supplies its own plain "Select objects: " prompt [and always in the plural], which I don't think there's any way to get around.  [It's not like (entsel) for which you can spell out your own prompt.]  I usually give a partial  prompt beforehand, for which the prompt (ssget) supplies is the conclusion, such as:
(prompt "\nFor those to be replaced,")
(ssget ....
Kent Cooper, AIA
Message 13 of 13
3dwannab
Looks like you were messaging as I posted my fix.
I didn't get the ssget prompt thing working but I thought I read somewhere that it's possible but that's not big deal. My main goal was to select the newly created block with sssetfirst
Thanks.
