Hiding a Layer/Symbol Start of a command and turning it back on when command end
Kyle.Pederson
Message 1 of 8
Kyle.Pederson
Could Someone explain how I could turn off or isolate a Particular Layer/symbol during a command and turn it back on after command is over?
Example would be LayerA, Symbol1, Symbol2, Symbol3. All need to be hidden before this area command is ran
Replies (7)
Message 2 of 8
ronjonp
Something like this?
;; Turn off and gather
(vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
  (cond	((wcmatch (strcase (vla-get-name x)) "LAYERA,SYMBOL[1-3]")
	 (vla-put-layeron x :vlax-false)
	 (setq l (cons x l))
;; Your code
;; Then turn them back on
(foreach x l (vla-put-layeron x :vlax-true))
A simpler solution would be to not include those layers in your selection set:
(ssget '((0 . "ARC,CIRCLE,LINE,*POLYLINE,REGION,SPLINE,ELLIPSE")
	 (8 . "~LayerA")
	 (8 . "~SYMBOL[1-3]")
Message 3 of 8
john.uhden
I'm a little confused.  Do you mean to change a layer's visibility property to OFF, or do you mean to eliminate the name from a list of layer names?
John F. Uhden
Message 4 of 8
Kent1Cooper
Also for clarification, are the "Symbol" entries just other Layer names, as Message 2 interprets it, or is a "Symbol" something different from  a "Layer," and if so, what do you mean by it?
Kent Cooper, AIA
Message 5 of 8
Kyle.Pederson
My issue is trying to accommodate older and newer drawings. Older drawings did not always have Tool Palette Blocks Saved under the correct layer. Newer drawings always have the Tool Palette Blocks saved under the layer "Symbols"
When I Run the Boundary Command It traces around certain Blocks that are placed on the actual Polyline. (Ex. Overhead Door) I'd like to have the Boundary Command go thru the Block to be a perfect Rectangle.
Seems like my best option to get around this is to Turn off Layer "Symbols" and/or Isolate a particular Tool palette Block during the beginning of the command, then have them all turn back on once command is done.
(defun C:Test1 (/ pt)
  (while (setq pt (getpoint "\nPick in closed area: "))
    (command "_.boundary" pt "")
Message 6 of 8
Kyle.Pederson
Layers to change visibility to Off and Tool Palette Blocks Isolate>Hide objects
Message 7 of 8
ronjonp
The first code snippet I posted should do what you want.
Message 8 of 8
ronjonp
Not sure how code savvy you are, but this is what I meant above:
(defun c:test1 (/ l pt)
    (cond ((wcmatch (strcase (vla-get-name x)) "LAYERA,SYMBOL*")
	   (setq l (cons x l))
  (while (setq pt (getpoint "\nPick in closed area: ")) (command "_.boundary" pt ""))
  (princ)
(vl-load-com)
