hide text that appears in the command window
carlos_m_gil_p
Message 1 of 15
carlos_m_gil_p
Hello boys how are you.
Can someone tell me how I can hide text that appears in the command window.
(defun c:xxx  (/)
  (setvar "cmdecho" 0)
  (command "-scalelistedit" "_r" "_y" "_e")
  (command "_.-purge" "_a" "" "_n" "_.-purge" "_r" "" "n")
  (command "_.-purge" "_r" "" "n")
  (setvar "cmdecho" 1)
  (princ)
I attached an image so you can understand me.
Thank you very much.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
Replies (14)
Message 2 of 15
cadffm
Try the handling with cmdecho
Sebastian
Message 3 of 15
carlos_m_gil_p
Hello how are you.
Thanks for your help.
I had already implemented it, as you can see in the code.
AutoCAD 2026
Message 4 of 15
Kent1Cooper
This question goes  > > w a y b a c k < < .  That's just one example -- put "Suppress Purge Command Echoing" into the Search window for some other threads on the same topic, and one the same about PEDIT.  Unfortunately, it doesn't seem there's any way to suppress echoing of certain elements of certain commands.
Kent Cooper, AIA
Message 5 of 15
cadffm
OMG, i am sorry it was written in hurry.
embarrassing
Sebastian
Message 6 of 15
jlojeda
(GRAPHSCR)
Message 7 of 15
carlos_m_gil_p
Hello how are you.
Thanks to everyone, I did not know that this text could not be hidden.
Thank you.
AutoCAD 2026
Message 8 of 15
jlojeda
Dear, write (GRAPHSCR) at the end of the code of your peogram, with this it will show the editor of autocad and therefore it will hide the text screen.
Message 9 of 15
carlos_m_gil_p
Hi, jlojeda, how are you?
I do not need to hide the window.
I need to hide the text. (the echo)
Excuse my English, I only speak Spanish
AutoCAD 2026
Message 10 of 15
jlojeda
A ok, sorry si por si ya lo escribieron más arriba pero, probaste con (setvar "cmdecho" 0) al inicio del programa?
Message 11 of 15
carlos_m_gil_p
Hola, no sabias que hablabas español.
Si ya lo probe, por eso coloque el codigo al principio para descartar esas opciones.
Pero solo pasa con algunos comandos.
Mil gracias por tu ayuda.
AutoCAD 2026
Message 12 of 15
jlojeda
A sí perdón, puedes usar esto para el purge, al menos es más silencioso:
(vla-PurgeAll (vla-get-activedocument (vlax-get-acad-object)))
Message 13 of 15
carlos_m_gil_p
Si lo intente, pero no es tan bueno como el otro.
Por ejemplo:
Cuando hay lineas con longitud cero, no las purga.
Por eso prefiero quedarme con el método que estoy utilizando. Jejeje.
AutoCAD 2026
Message 14 of 15
jlojeda
Para borrar las lineas de longitud = 0:
(setq sel (ssget "X" (list (cons 0 "LINE"))))
(if sel
(progn
(setq n 0)
(repeat (sslength sel)
(setq ename (ssname sel n))
(setq startpoint (cdr (assoc 10 (cdr (entget ename)))))
(setq endpoint (cdr (assoc 11 (cdr (entget ename)))))
(setq dist (distance startpoint endpoint))
(if (= dist 0.0)(entdel ename))
(setq n (1+ n))
(princ)
Message 15 of 15
carlos_m_gil_p
Hola hermano, gracias por esa solución.
Es mas código pero valida.
Un saludo.
AutoCAD 2026
