hi sir, i want "2 space" front and back of chainage in this lisp.
kkr028
Message 1 of 8
kkr028
hi sir, i want "2 space" front of chainage in this lisp.
front 2 space and back 2 space.
actual "0.000"
i want "  0.000  "
(defun C:CHAINAGE ; = Chainage Text at Intervals
(/ interval ss n pl dst pt)
(setvar 'dimzin 0)
(command "_.layer" "_make" "Chainage" "")
(setvar 'textsize (getdist "\nChainage Text Size: "))
(setq
interval (getdist "\nChainage Interval: ")
ss (ssget '((0 . "*POLYLINE")))
); setq
(repeat (setq n (sslength ss))
(setq
pl (ssname ss (setq n (1- n)))
dst 0
); setq
(while (<= dst (vlax-curve-getDistAtParam pl (vlax-curve-getEndParam pl)))
(command "_.text"
"_non" (setq pt (vlax-curve-getPointAtDist pl dst))
"" ; height
(cvunit ; rotation
(+ (angle '(0 0 0) (vlax-curve-getFirstDeriv pl (vlax-curve-getParamAtPoint pl pt))) (/ pi 2))
"radian" "degree"
); cvunit
(rtos (/ dst 1000) 2 3)
); command
(setq dst (+ dst interval))
); while
); repeat
(princ)
); defun
Replies (7)
Message 2 of 8
ВeekeeCZ
  (setvar 'dimzin 0)
  (setq
    ); setq
    (setq
      dst 0
      ); setq
      (command "_.text"
	       "" ; height
	       (cvunit ; rotation
		 "radian" "degree"
		 ); cvunit
	       (strcat "  " (rtos (/ dst 1000) 2 3) "  ")
	       ); command
      ); while
    ); repeat
  (princ)
  ); defun
Message 3 of 8
calderg1000
Regards @kkr028
In my opinion the space in front of the text is enough, behind it it would not be necessary
(strcat " "(rtos (/ dst 1000) 2 3))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 4 of 8
calderg1000
Dear @kkr028
I made some small changes to improve the insertion time of the texts. Command is somewhat slow.
(defun C:CHAINAGE(/ interval ss n pl dst pt); = Chainage Text at Intervals
  (setvar 'dimzin 0)
  (setvar 'textsize (setq th (getdist "\nChainage Text Size: ")))
  (setq
  )                                               ; setq
    (setq
      dst 0
    )                                             ; setq
;;;(command "_.text" "_non"
;;;"" ; height
;;;(setq ang(cvunit ; rotation
;;;(+ (angle '(0 0 0) (vlax-curve-getFirstDeriv pl (vlax-curve-getParamAtPoint pl pt))) (/ pi 2))
;;;"radian" "degree"
;;;)); cvunit
      (setq ang
             (+ (angle '(0 0 0)
                (/ pi 2)
      (setq tt (strcat " " (rtos (/ dst 1000) 2 3) " "))
;;;); command
      (entmake (list '(0 . "text")
                     (cons 10 pt)
                     (cons 50 ang)
                     (cons 40 th)
                     (cons 1 tt)
    )                                             ; while
  )                                               ; repeat
  (princ)
)                                                 ; defun
Carlos Calderon G
Message 5 of 8
kkr028
fantastic sir. i love it. i toomuch tired when chainage marking. it is taking time to label chainage.
with this lisp you help me a lot (space and time).
thank you sir.
Message 6 of 8
calderg1000
Happy to help. Cheers
Carlos Calderon G
Message 7 of 8
pbejse
actual "0.000"
i want "  0.000  "
Not a big fan of adding unnecessary spaces on numerical values, i'd rather push the  insertion point with a factor based on the text height.
Using @calderg1000  bit on entmake.
             (cons 10 (polar pt ang (* 0.25 th)))
             (cons 50 ang)
             (cons 40 th)
             (cons 1 tt)
But that's just me
HTH
Message 8 of 8
calderg1000
Regards @kkr028
@pbejse's proposal is great, but I prefer a larger spacing factor that also allows the insertion of a TICK, as in C3D.
Please try this additional code.
(defun C:CHAINAGE (/ interval ss n pl dst pt)     ; = Chainage Text at Intervals
  (setvar 'dimzin 0)
  (setq
  )                                               ; setq
    (setq
      dst 0
    )                                             ; setq
      (setq ang
             (+ (angle '(0 0 0)
                (/ pi 2)
      (setq tt (rtos (/ dst 1000) 2 3))
                     (cons 10 (polar pt ang (* 1.25 th)))
                     (cons 50 ang)
                     (cons 40 th)
                     (cons 1 tt)
      (entmake (list '(0 . "line")
                     (cons 10 (polar pt ang (- (abs th))))
                     (cons 11 (polar pt ang th))
    )                                             ; while
  )                                               ; repeat
  (princ)
Carlos Calderon G
