Help Xline Layer Control
Temssi.d
Temssi.d
hi'
I have this script,
(defun C:2 (/ dis)
  (setvar 'cmdecho 1)
  ; Create the first Xline
  (command "_.xline" "_ver" pause "")
  (while (setq dis (getdist "\nDistance to next Xline: "))
    (command "_.copy" "_last" "" "_non" "@" "_non" (polar (getvar 'lastpoint) 0 dis))
  ); while
  (prin1)
I need to change it so it will create vertical Xlines and Place all Xlines on a designated layer (e.g., "layer1") without permanently altering the current layer setting.
thanks!!!
komondormrex
hi,
like that?
(defun C:2 (/ dis)
  (setvar 'cmdecho 1)
  (vla-put-layer (vlax-ename->vla-object (entlast)) "layer1") ;added. puts 1st xline to existing "layer1"
  ); while
  (prin1)
paullimapa
May want to check to make sure layer1 exists and if not create it
Paul Li
IT Specialist
@The Office
Temssi.d
yep!
thanks 👏😃
