Help with text string
I have a variable "PanelNumber"
This may equal "123" or "A123" or "B123" or "C123" etc..
I want to look at the variable and if the first character of the string is a letter run subprogram "program1" or if the first character is a number then run subprogram "Program2"
Is this possible?  I am able to strip and return the first character, but unsure how to determine if its a letter of number.
Thank you in advance!!
Ranjit_Singh
Many ways to do this. One example
(setq var_name "A123")
(if (wcmatch var_name "[0-9]*") "call prog2" "call prog1"))
or
(if (wcmatch var_name "#*") "call prog2" "call prog1"))
This appears to work, but I have a follow up question..
Is it possible to set a variable that is equal to the first character?
For instance.. "PanelNumber variable is P123, I want to (setq First_Char "P")
For instance.. "PanelNumber variable is X123, I want to (setq First_Char "X")
Kent1Cooper
Look into the (substr) function [= SUBSTRing from a longer one]:
(setq First_Char (substr PanelNumber 1 1))
Kent Cooper, AIA
Thank you sir!!  Very much apperciated
