Help with selection and loop
mid-awe
mid-awe
Hey all, I am working on a simple piece of code that will place a leader at the insertion point of every block with a specified name. Hears the good part then I want to select each of the added leaders and use the QLATTACH to connect the leaders to a specified string in the drawing. below is the code that I have so far, and what it doesn't do is select all of the newly added leaders only the first one. Please help. Thanks in advance.
[code] (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 blockname)))
n (1- (sslength ss))
(while (>= n 0)
(setq blockname (ssname ss n)
n (1- n)
inspt (cdr (assoc 10 (entget blockname)))
(command "._LEADER" inspt "@12<0" "" "" "N")
(setq ldrs (entlast))
(COMMAND "QLATTACH" ldrs PAUSE)[/code]
Replies (7)
Look at the help for (ssadd) to see how this works:
[code]
ldrs (ssadd)
(while (>= n 0)
n (1- n)
(ssadd (entlast) ldrs)
[/code]
wrote in message news:4926902@discussion.autodesk.com...
or - to be geeky tweaky...
code]
n (sslength ss)
ldrs (ssadd)
(repeat n
(setq n (1- n)
[/code]
Princess Jamie,
Life shrinks or expands in proportion to one's courage.
- Anais Nin
mid-awe
I'm not sure of the problem. I've just spent the last half hour studying both versions of this code and the developer documentation set on ssadd but I do not see why this will not attach all of the leaders to the text. I did add all of the variables to the (defun addleader (/ blocknamess n ldrs inspt)) It still only connects the first leader to the text.
I tested QLATTACH and noticed that it only allows one leader to be selected and then the text. How can I do this will I have to repeat the QLATTACH command for the unspecified number of times. Can I use foreach or ...?
Thanks for you help
Well, I obviously didn't test the code ;-/
I don't think I've ever used the QLATTACH command so I did not realize it
was a 'one at a time' type of command.
So you could either run the QLATTACH immediately after creating each leader,
Or, still using the code that creates the ldrs SS, do a (while) or (repeat)
with that SS to invoke the QLATTACH on each leader,
Or, you could look into using ActiveX to set the Annotation property of the
leader object.
wrote in message news:4927463@discussion.autodesk.com...
Thanks for you help
mid-awe
Thanks, I'll give your suggestions a try. I'm still new enough at this that I was proud of my self for my original code. I'll learn a lot if I figure this one out.
Thanks again to everyone who helped.
n (sslength ss)
ldrs (ssadd)
(repeat n
(setq n (1- n)
(command ".LEADER" inspt "@12<0" "" "" "N")
(command ".qlattach" (entlast) blockname)
[/code]
like this? I assume attreq has to be set properly...
Princess Jamie
wrote in message news:4927677@discussion.autodesk.com...
this one out.
mid-awe
Sweet! That works great. Thank you so much. Princess Jamie 🙂
This is what I finished with.
[code](defun mldr_attch (STRING blockname / TXT ss n ldrs inspt)
(command "_.mtext" PAUSE "J" "MC" "W" "0" STRING "" "")
(SETQ TXT (ENTLAST))
n (sslength ss)
ldrs (ssadd)
(repeat n
(setq n (1- n)
(command ".qlattach" (entlast) TXT)
)[/code]
