Help with routine to create layer
msarqui
Message 1 of 11
msarqui
I made this simple routine to create a layer :
(defun c:createLayerTex (/ acadObj doc layers newLayer)
(setq acadObj (vlax-get-acad-object)
 doc (vla-get-ActiveDocument acadObj)
 layers (vla-get-Layers doc)
 newLayer (vla-Add layers "Tx-0-Textes")
);setq
;I set the following vla-put, because If the layer already exists, and If it does not have this properties, I would like to replace those informations.
  (vla-put-color newLayer 5)
  (vla-put-linetype newLayer "Hidden")
  (vla-put-layeron newLayer :vlax-true)
  (vla-put-freeze newLayer :vlax-false)
  (vla-put-Lock newLayer :vlax-false)
);defun
My problem is:
If I already have this layer in my drawing, and it is not current, nothing happens. That is OK.
But, If I already have this layer in my drawing, and it is current, the following message appears :
Command: CREATELAYERTEX
; error: Automation Error. Invalid layer
Any help?
Thanks.
Replies (10)
Message 2 of 11
Kent1Cooper
This is one of the reasons I prefer to just use a Layer command:
(setq LayName "Tx-0-Textes")
(command "_.layer" "_thaw" LayName "_make" LayName "_unlock" LayName "_color" 5 "" _ltype" "hidden" "" "")
It takes care of a lot of that other stuff for you.  It won't care whether or not the Layer already exists in the drawing, even for Thawing before it even exists.  [You need to do that because if it does exist but is Frozen, it can't be made current, so you can't use its name in the "_make" option.]  It will make it current, whether or not it exists already.  It will turn it on if it's off.  It will force the color and linetype to your standards if the Layer already exists but with different settings for those.
If you don't necessarily want the new Layer to be current when it's done, you can either:
A.  precede the above with (setq clay (getvar 'clayer)) and follow it with (setvar 'clayer clay), or
B.  use the "_new" option instead of "_make", add an "_on" option in case it exists but is off, and give it the Layer name specifically for the "_on" option and for the color and linetype assignments in lieu of the Enters that accept the current Layer name as default.
Yes, technically, this would be "slower" than the other method, but not by an amount that would be even remotely detectable by a User [certainly far less time than it takes to click and release a mouse button], unless you have a very large number of Layers to create lumped together into a collective routine.
Kent Cooper, AIA
Message 3 of 11
hmsilva
msarqui wrote:
My problem is:
Hi msarqui,
using vla-Add method to add a layer to layer collection, we'll have to ensure that ltype is loaded before we set a layer with it, and if layer is the current one, we can not change the freeze property...
Something like this will do the trick
(defun c:createLayerTex (/ acadObj currlay doc flag layers ltypes newLayer)
        ltypes   (vla-get-Linetypes doc)
        currlay  (vla-get-ActiveLayer doc)
  );setq
  (vlax-for lt ltypes
    (if (wcmatch (strcase (vla-get-name lt)) "HIDDEN")
      (setq flag t)
  (if (null flag)
    (vla-load ltypes "Hidden" "acadiso.lin")
  (if (not (wcmatch (strcase (vla-get-name currlay)) "TX-0-TEXTES"))
  (princ)
);defun
Hope this helps,
Henrique
Message 4 of 11
Kent1Cooper
@Kent1Cooper wrote:
It takes care of a lot of that other stuff for you. ....
And another thing:  It does not require the linetype to be loaded into the drawing already -- it will find it.
Kent Cooper, AIA
Message 5 of 11
msarqui
Hi Henrique
@hmsilva wrote:
...and if layer is the current one, we can not change the freeze property...
I've been studying your code to learn and realized that maybe this wil be necessary only if I have this way:
    (vla-put-freeze newLayer :vlax-true)
Because if the layer is freeze, it certainly will not be the current one.
Am I right?
Thanks for your help.
Message 6 of 11
msarqui
Hi Kent
You're right. Sometimes the best thing is to keep it simple and straightforward. I had done before the way you said and it works very well. However, I would like to know how to get around this problem in VLISP because I'm trying to learn it.
Thanks a lot.
Message 7 of 11
hmsilva
@msarqui wrote:
Hi Henrique
Am I right?
Hi msarqui,
No.
Your code is generic, you don't know if layer exists, if is freeze or locked or current or... as I had previously said, '...and if layer is the current one, we can not change the freeze property...' so, if we 'put' 'true' or false' we are modifying the propertie (even if we don't change the property current value) and will give the ' ;error: Automation Error. Invalid layer'
As your code is generic, you could modify it to a function,
i.e.
;; usage
;; (createLayer "test" nil nil)
;; to create a layer "test" with default color and linetype
;; (createLayer "test" 1 nil)
;; to create a layer "test" with color 1 and default linetype
;; (createLayer "test" 3 "center")
;; to create a layer "test" with color 3 and linetype center
(vl-load-com)
(defun createLayer (layname color ltype / acadObj currlay doc flag layers ltypes newLayer)
        newLayer (vla-Add layers layname)
  (if ltype
    (progn
      (vlax-for lt ltypes
        (if (wcmatch (strcase (vla-get-name lt)) (strcase ltype))
          (setq flag t)
      (if (null flag)
        (vla-load ltypes ltype "acadiso.lin")
      (vla-put-linetype newLayer ltype)
  (if (not (wcmatch (strcase (vla-get-name currlay)) (strcase layname)))
  (if color
    (vla-put-color newLayer color)
Hope this helps,
Henrique
Message 8 of 11
redtransitconsultants
You just need to search the layer table for the name to check if it exists already. Here's some code to do that...
(if (tblsearch "LAYER" "MY-LAYER-NAME") ;Check if the layer exists
  (progn
    ;;Found layer, do something
  ) ;End if progn
  (progn
    ;;Cannot find layer, skip, or do something else
  ) ;End if progn
) ;End of if
Additionally, you could get the currently layer and store it in memory temporarily, change the layer to something else like 0, do something, then when done change it back and the user wouldn't know the difference.
(setq oldlayer (getvar "CLAYER"))
(setvar "CLAYER" "0")
;;Do something here
(setvar "CLAYER" oldlayer)
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Message 9 of 11
msarqui
Hi Steve,
I had already tried that. I do not know why but I could never do tblsearch work with VLISP. Maybe I am missing something.
Well, I had also thought of changing the layer, but I thought this would be a palliative solution. I think Henrique showed a great way to solve the issue.
Thanks!
Message 10 of 11
msarqui
@hmsilva wrote:
Hi msarqui,
No.
Hi Henrique,
You are right. I made some tests and the error came out again. I understand now the logic. Thanks for the explanation.
i.e.
;; usage
(vl-load-com)
  (if ltype
    (progn
      (vlax-for lt ltypes
          (setq flag t)
      (if (null flag)
  (if color
This is amazing! I have lots of "create layers routines" and now I can use only this function to do that. This is really good!
Thanks again.
Marcelo
Message 11 of 11
hmsilva
You're welcome, Marcelo!
Glad I could help
Henrique
