Help with reading text file into dcl listbox
DC-MWA
DC-MWA
Hi all,
Trying to read from a text file into a dcl list box.
Can't seem to get it to work. I have attached the lisp and my attempts within.
I'm guessing this is just something obvious I'm missing.
-dc
SeeMSixty7
Updated these two sections of your code
(setq myList1 (list))
(setq openfile (open "TEST2.txt" "r"))
(while (setq line (read-line openfile))
   (setq txtlist (append txtlist (list line)))
(close openfile)
and instead of using mapcar used a foreach.
	   (start_list "mylist1")
	   (foreach txtline txtlist (add_list txtline))
	   (end_list)
It works fine now
dlanorh
See if this works (not tested)
(setq myfile "TEST2.txt")
(setq myList1 nil) ;NIL is a list you can test by using (listp nil). This avoids null strings ("") in lists of text
(cond ( (findfile myfile)
        (setq openfile (open myfile "r"))
          (setq myList1 (cons line myList1))
        );end_while
        (close openfile)
      (t (alert (strcat "File " myfile " NOT Found")))
);end_cond
Then later
 (start_list "mylist1" 3);; The 3 is not needed as this is the default if omitted
 (mapcar 'add_list (reverse myList1))
 (end_list)
I am not one of the robots you're looking for
DC-MWA
thank you.
DC-MWA
thank you for your input. I'm trying this as well.
SeeMSixty7
You are very welcome!
