Here is what it shows when running on two files. (It looks like it's doing something but if you open the files after the fact, it seems as though nothing has happened.)
Command: BATCHPURGE
Unknown command "DWG". Press F1 for help.
No unreferenced blocks found.
No unreferenced layers found.
No unreferenced linetypes found.
No unreferenced text styles found.
No unreferenced shape files found.
No unreferenced dimension styles found.
No unreferenced mlinestyles found.
No unreferenced plotstyles found.
No unreferenced table styles found.
No unreferenced materials found.
No unreferenced visual styles found.
No unreferenced multileader styles found.
No unreferenced groups found.
No unreferenced Detail view styles found.
No unreferenced Section view styles found.
I have attached two files that I used..
