Help with Nil and not found message
kthmarks
kthmarks
I have tried to figure this out but I continue to either get errors or, when I do get success I get the "no objects found" message even when there is one.  I am obviously a noob but can't wrap my head around the If statement or if I even need it with the sssetfirst command.
I'm sure I am over complicating this.
SMH
(defun C:GET_N (/ echo ssN)
(setvar "Expert" 3)
(setq echo (getvar 'cmdecho))
(setvar 'cmdecho 1)
;;(sssetfirst nil ssN)
(prompt
(if setq ssN (ssget "_x" '((8 . "*NEW*"))))
;;(command "select" ""))
(print "No objects found"))
(princ)
ВeekeeCZ
Possibly like this?
...to select all objects in *new* layer at current space. Limit to current space is there because we're unable to select/highlight them anyway.
(defun C:GET_N (/ ssN)
(if (setq ssN (ssget "_x" (list '(8 . "*NEW*") (cons 410 (getvar 'ctab)))))
  (print "\nNo objects found"))
(princ)
kthmarks
Perfect thank you @ВeekeeCZ .  I'm ashamed to admit how long it took me to ask for help.  I really appreciate it.
ВeekeeCZ
You'll learn nothing if you ask for help right away. So...
Moshe-A
@kthmarks  hi,
check this  😀
 (setvar "cmdecho" 0)
 (setvar "expert" 3)
 (if (setq ssN (ssget "_x" '((8 . "*NEW*"))))
  (prompt "No objects found")
 (setvar "expert" 0)
 (setvar "cmdecho" 1)
 (princ)
ВeekeeCZ
@Moshe-A that's not fun. Those sysvars have no effect on the process. Just messing with his head. Besides, it's not good example on how to correctly reset them.
