Help with multi-leader lisp
codyt8VRMG
codyt8VRMG
I  have no programming experience so I am hoping someone can help me make a lisp file.
I need it too pull out 3 points of data from the block and place them in a multi-leader.
I have included images of what I would like it to look like, the data I need include and the block construction.
If needed I can upload an autocad file.
If it is important I am using autocad 2023
ВeekeeCZ
Yes, post the dwg file.
codyt8VRMG
I edited the original post as well.
Thank you
ВeekeeCZ
Try this. I needed to restrict a leader's points to 2. Or it could be 3 if you like, but it needs to be a fixed value.
(defun c:StairCallout ( / s m b d f r w)
  (if (and (setq s (car (entsel "\nSelect a block: ")))
	   (setq m (getstring "\nRise: "))
	   (setq b (tblobjname "block" (cdr (assoc 2 (entget s)))))
	   (progn
	     (while (setq b (entnext b))
	       (and (setq f (entget b))
		    (= "ATTDEF" (cdr (assoc 0 f)))
		    (= "STAIR_DESCRIPTION" (cdr (assoc 2 f)))
		    (setq d (cdr (assoc 1 f)))))
	     d)
	   (setq r (getpropertyvalue s "AcDbDynBlockPropertyRUN"))
	   (setq w (getpropertyvalue s "AcDbDynBlockPropertyWIDTH"))
    (command "_.mleader" pause pause "_E" (strcat d "\\P" (rtos r) " X " m "\\P" (rtos w) "W")))
  (princ)
codyt8VRMG
This is amazing thank you!
If possible is it possible to convert the width to a fraction?
If not I can still work with this and appreciate the help!
ВeekeeCZ
It uses your current UNITS setting.
But we can override it by (rtos w 5). according to THIS
codyt8VRMG
It is a bit of an awkward set up because we need decimal units for other more accurate parts.
This however worked perfectly for these notes!
Thank you so much!
