Help with load command
Message 1 of 26
I created a few shapes with mkshape.
But every time i restart autocad I need to LOAD again the shx files.
How to let autocad load automatically the shx files at startup?
Replies (25)
Message 21 of 26
john.uhden
I'm not sure I can trust you either.😂
Rectangular road designs? Is that what Foster's does to you?
John F. Uhden
Message 22 of 26
Moshe-A
Guys,
@john.uhden
@Sea-Haven
Looks like you did not read\see what the OP wants? she has a lisp that create a layout with coordinates base on a rectangle she manually draws on model. the lisp covers this task, noting  more.
Moshe
Message 23 of 26
Absolutely perfect!
exactly the lisp i was looking for.
thank you very much for your help.
Message 24 of 26
hi moshe,
how can i edit this vlx file? the a3/a4 size is a bit large then the a3/a4 print size.
i attached the rectangles that i made for eace paper size
Message 25 of 26
Moshe-A
Shani,
yes i see the problem, had a major bug in scale...i will fix that as soon as possible
you do not use standard media size at all?  😀
moshe
Message 26 of 26
What do you mean by standard media size?
I use A0 in different lengths, and a3 + a4.
I use the 250,500,1000 scale because it currently fit to our project programs.
