Help with how to insert a folder full of drawings into a file in one instance, possible?
Jonathan.Gray68UQW
Jonathan.Gray68UQW
Hello all,
I have a folder full of drawings (39 actually) that I would love to have a routine that would allow me to import all of the files into a blank drawing in a single command.   My vision would be I would issue the command and then multiple select all the .dwg files or just point to a single folder that held all 39 of the files then the command would pull all these drawings into my current drawing in one instance.
These drawings are actually a tile set of contours that when placed together make a complete picture of an area.
The drawings have been made so that if you insert each of them next to each other at a basepoint of 0,0 they perfectly align with each other.
Does anybody know of a routine that can help me?
ВeekeeCZ
If you ask at autocad forum they will recommend you to use xrefs and then binding them.
Jonathan.Gray68UQW
This was the perfect answer!  Thank you so much :). This will save me about an hour of work at least.
pendean
Community Legend
Community Legend
How would the LISP (or AutoCAD) know how to sort them (which comes first, second, third, last etc.), how to space them/place them, at what grid/coordinates for each and more exactly?
Provide details, very specific details, for help developing a routine.
TIA
Jonathan.Gray68UQW
Hello there!  My friend above just gave me the perfect answer :). However, thank you for taking the time to look into this for me as that over the years you have actually answered a lot of questions for me 🙂
chaitanya.chikkala
Attached LISP routine might also help you, incase you need in future. (Command -> INSERT_DWGS)
