Good morning,
At this point in my code, all I am trying to do is get user input in an edit_box in my dcl, and pass it to a global variable. That's it. Not trying to use that variable for anything yet... just capture it. No matter what I try I get some sort of an error, mostly ; error: bad argument type: stringp nil, when trying to view Alert the value.
Eventually I will be using this with a block attribute increment program. I found that code in these forums and it works great.... but I need to be able to use these global variables.
My dcl and lsp are attached, would someone have time to take a peek? TIA!!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
