Help with Autolisp/Macro
Sujan.Maharjan
Sujan.Maharjan
I have no knowledge with programming. Anyone any help with any Macro/Autolisp to speed up this process? I posted with screencast here.
"Revit Lies in the tension between what we want to do and what can be done!"
john.uhden
The first thing I noticed was your method of filleting.  You seemed to be pointing to the radius to use.  Why not Fillet;radius?
The second thing is you drew the polyline and then changed its properties.  Why not just set the desired layer first with its color and linetype properties?
I'm sure there is something here to offset to a different layer.  That could save some time.  To write something to wrap it all up would be very helpful, but we here try to help others help themselves rather than doing everything for them.  It's time for you to start learning AutoLisp, make your mistakes, and then ask for help in guiding you to achieve your goals (and improving your skills).  Then you can return the favor by being a contributing member.
John F. Uhden
Sujan.Maharjan
I'm not a programmer but trying to start with macro now. I'm willing to improve furthur.
Here my intension was to draw a polyline of desired length(no. of clicks) then fillet with desired radius. I couldn't figure out how do I do that. Is it possible with macro?
john.uhden
Command:  Fillet; R; <enter value>; pick two adjacent segments.
Okay.  Here's a slightly helpful command function:
(defun c:FR ()
  (setvar "cmdecho" 0)
  (command "_.fillet" "_Radius")
  (setvar "cmdecho" 1)
  (while (> (getvar "cmdactive") 0)(command pause))
  (princ)
John F. Uhden
Sujan.Maharjan
Hi @john.uhden, this is where i'm now. My main problem with this is double offset only work with "last created object". How to do entire process from single macro?
john.uhden
Study, trial, and error.  That's mostly how I learned.
John F. Uhden
