HELP with a script to rename layout tabs
tetenteten
Observer Observer
tetenteten
Observer
Observer
I use Autocad LT every day for work and have created a template with a number of layouts with a standard title.
I would like to create a script that can rename the title of the layout tab so that I don't have to do this manually.
I have already had a script created by 'ChatGPT', but this does not work.
can anyone help me to create a script to rename the layout tabs?
this was the script:
(defun c:RenameLayouts ()
(vl-load-com) ; Load the Visual LISP functions
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ; Get the active document
(setq layouts (vla-get-Layouts doc)) ; Get the layout collection
(vlax-for layout layouts
(setq layoutName (vla-get-Name layout))
(cond
((= layoutName "L_V_XXXX")
(vla-put-Name layout "L_V_1111")) ; Rename 'L_V_XXXX' to 'L_V_1111'
((= layoutName "L_B_XXXX")
(vla-put-Name layout "L_B_1111")) ; Rename 'L_B_XXXX' to 'L_B_1111'
(princ) ; End function
thank you
Moshe-A
@tetenteten hi,
Check this corrected version.
enjoy
Moshe
(vl-load-com) ; Load the Visual LISP support
(defun c:RenameLayouts (/ doc layouts layout layoutName)
  (cond
    (vla-put-Name layout "L_V_1111") ; Rename 'L_V_XXXX' to 'L_V_1111'
   ); case
    (vla-put-Name layout "L_B_1111") ; Rename 'L_B_XXXX' to 'L_B_1111'
  ); cond
  (vlax-release-object layout)
 ); vlax-for
 (vlax-release-object layouts)
 (vlax-release-object doc)
 (princ) ; quiet exit
); c:RenameLayouts
-didier-
Bonjour @tetenteten
Usually I don’t give an answer referring to ChatGPT.
We are not here to solve the problems generated by AI.
We are humans who talk to humans.
I make an exception and I tested the code, and it works,
you say that it does not work, let’s admit!
What is the error message?
What version of LT do you use?
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
tetenteten
Observer
Observer
wauw, thanks @Moshe-A .
this works really great.
thank you very much
