Help w/ Complex Linetype edit
MKH-VB
Message 1 of 9
MKH-VB
I have a gas line complex linetype. (see definition below).  I am trying to make it to where the text is always upright no matter which way the line was drawn.  Notice in my def's below, that I have changed the "R" to "U", which I thought would do the trick. Can anyone enlighten me on why this is not working?  I use multiple dviewed viewports and this would sure help me out. Thanks
*GAS LINE, ----G----
A,.40,-0.120,["G",HW-ITALIC,S=0.08,R=0.000,X=-0.100,Y=-0.033],-0.030
*GAS LINE Rotate, ----G----
A,.40,-0.120,["G",HW-ITALIC,S=0.08,U=0.000,X=-0.100,Y=-0.033],-0.030
mkh
Replies (8)
Message 2 of 9
h_s_walker
Change R=0 to A=0. See the link below. Be aware though you will need to fiddle with the alignment of the text if you don't it will appear as in the image below
How to create complex linetypes in AutoCAD
Howard Walker
Left Handed and Proud
Message 3 of 9
MKH-VB
thanks for that...but the "A" designator makes all text horizontal....I am needing it parallel with the linework.
M.
mkh
Message 4 of 9
h_s_walker
Then you need to use the U as you have done in the second one.
Howard Walker
Message 5 of 9
MKH-VB
notice that in my example sent, I did use the U=0 designator.
mkh
Message 6 of 9
h_s_walker
Show what you what you are getting. The image below is using the inbuilt HW linetype which has U=0
Howard Walker
Message 7 of 9
MKH-VB
thank you...I think I misunderstood the function of the U option.  I was hoping that in a dview of 180 degrees, that the text would still be plan readable.  Is that even possible?
m
mkh
Message 8 of 9
h_s_walker
@MKH-VB No I don't think it is. The only think I can think of is do a dashed line over a solid line, make the dashed line one colour and the solid line another, and designate that as your gas line.
Howard Walker
Message 9 of 9
Sea-Haven
We often had this problem so for a pline just use Reverse. This will flip the text. A line need to rotate 180.
