I have used the attached lisp routines for years but with Civil 3D 2015 it seems to not want to work. I'm not sure why, but I suspect it has something to do with the exporting map information dialog box that pops up when doing a WBLOCK command.
I have searched for the original author, (c)2001, Justin D. Andrews, but cannot find him so I hope it is okay asking for the communities help now.
The issue I am having is after choosing the object:
Would anyone with LISP and Civil 3D knowledge be willing to help me figure this out?
Or, if anyone else knows of a lisp that handles WBLOCKs in a similar manner, I would love to hear about it.
Solved by CADaSchtroumpf. Go to Solution.
I have changed in the code the path "C:" to (strcat (getvar "ROAMABLEROOTPREFIX") "support\\xxx.xxx")
because if you not have permission to write in c:\ , the program don't work's properly.
Try this version, if seem to work's
Seems to be working like a charm now. Thank you so very much. I would hate to lose this lisp. Can't find any other like it yet.
