Help to filter text, mtext and attribute
msarqui
msarqui
Hi guys,
I am trying to make a filter but something is wrong. Could you help me please?
(defun C:FT (/ ent)
(while
(setq ent (nentsel "\n  **  Select Text, Mtext, Attribut or <exit>:  **"))
(progn
	(cond
		((eq (cdr (assoc 0 (entget (car ent)))) "TEXT")
			  (command "_textedit" ent)
		);eq
		((eq (cdr (assoc 0 (entget (car ent)))) "MTEXT")
		  	  (command "_mtedit" ent)
		);eq
		((eq (and (cdr (assoc 0 (entget (car ent)))) "ATTRIB")
			  (= "A" (cdr (assoc 2 ent)))   ;<------I think the problem is here. I am trying to filter an attribute tag A
		     );and
			  (command "_attipedit" ent)
		);eq
		          (= "G02" (cdr (assoc 2 ent)))   ;<-------And here. I am trying to filter an attribute tag G02
		     );and
			  (command "_attedit" ent)
		);eq
	);cond
);progn
);while
);defun
Marcelo
Kent1Cooper
I think you have some function names reversed, and you're trying to extract information from an entity name that needs to come from its entity data list.  Try changing this part:
      );and
   );eq
      );and
   );eq
to this [I'm using (=) instead of (eq) -- either should work]:
  ( (and
      (= (cdr (assoc 0 (entget (car ent)))) "ATTRIB")
      (= "A" (cdr (assoc 2 (entget (car ent)))))
    );and
  ); tag A condition
  ( (and
      (= "G02" (cdr (assoc 2 (entget (car ent)))))
    );and
  ); tag G02 condition
I would suggest saving (entget (car (ent))) as a variable prior to the above, to shorten it.
Kent Cooper, AIA
hmsilva
Hi Marcelo,
the
_$ (setq ent (nentsel "\n  **  Select Text, Mtext, Attribut or <exit>:  **"))
(<Entity name: 7ffffb2a050> (2021.98 1624.74 0.0))
_$ (command "_attedit" ent);<===
; error: Function cancelled
will raise an error, we need to call 'initdia' first...
I would do something like this:
(defun C:FT (/ ent nsel typ)
    (while
        (and (setq nsel (nentsel "\n  **  Select Text, Mtext, Attribut or <exit>:  **"))
             (setq ent (entget (car nsel)))
             (setq typ (cdr (assoc 0 ent)))
           (cond
               ((eq typ "TEXT")
                (command "_.textedit" nsel)
               ) ;eq
               ((eq typ "MTEXT")
                (command "_.mtedit" nsel)
               ) ;eq
               ((and (eq typ "ATTRIB")
                     (eq (cdr (assoc 2 ent)) "A")
                ) ;and
                (command "_.attipedit" nsel)
               ) ;eq
                     (eq (cdr (assoc 2 ent)) "G02")
                ) ;and
                (initdia)
                (command "_.attedit" nsel)
               ) ;eq
               (T
                (princ "\nYou've selected a wrong entity type...try again... ")
               ) ;T
           ) ;cond
    ) ;while
    (princ)
) ;defun
Hope this helps,
Henrique
msarqui
Kent and Henrique,
Both are working 🙂
Thanks for your help!
Marcelo
