Help: Reactors Action when select a block with attributes
Luís Augusto
Luís Augusto
Hello guys.
Could you give me an example of reactors?
I would like was performed an action, when select a block with attributes. (Only click)
The event should be triggered if the selection contains only a single object.
Thank you in advance.
Best regards, Luís Augusto.
ВeekeeCZ
As a starting point....
Spoiler
(defun c:BlockSelect_UnLoad ()
  (if *BlockSelect_miscellaneousReactor*
    (vlr-remove *BlockSelect_miscellaneousReactor*))
  (princ)
(defun BlockSelect_OnLoad ()
  (setq *BlockSelect_miscellaneousReactor* (vlr-miscellaneous-reactor
					     nil
					     '((:vlr-pickfirstmodified . BlockSelect_CallBack))))
  (princ "\nBlockSelect is running ")
  (princ)
(defun BlockSelect_CallBack (rea lst / ss obj i)
  (if (and (setq ss (cadr (ssgetfirst)))
	   (= 1 (sslength ss))
	   (= "INSERT" (cdr (assoc 0 (entget (ssname ss 0)))))
	   (= 1 (cdr (assoc 66 (entget (ssname ss 0)))))
    (princ "\n *** Single block with att selected ***"))
  (princ)
(BlockSelect_OnLoad) ; Starts the reactors.
Luís Augusto
BeekeeCZ, exactly what I needed to start.
Sorry request help without starting code, I was not able to understand the reactors. This issue seemed a bit confused.
But now I understood the code you wrote, using the debugger Vlide.
Thank you so much for the great help. Smiley Very Happy
I believe you demystified this issue for me.
It may be precipitated, but I now believe that I am able to understand the mechanisms of the reactors.
I am very grateful for your help. I know you use your time to help me.
