help pulling info from middle of dwgprefix
Travis.Biddle
Travis.Biddle
I need to pull one of the folder names from the dwgpreix variable.
"C:\\Users\\trab01\\Box\\AX Projects\\S012345 Test\\Production\\Truck 12\\Programs\\INSULATION_XPS_2.5\\Nest 1\\TXT\\"
I need to pull the "S012345 Test" from the prefix.  So basically need to pull from the "SO" to the first "\\"
note:
The character combination of "S0" will never appear anywhere else in the string
Character counts before and after this location will change from drawing to drawing.
Can anyone please help?
Accepted solutions (3)
Replies (10)
paullimapa
Try this...after saving & loading get_val.lsp enter at Command prompt:
(get_val "C:\\Users\\trab01\\Box\\AX Projects\\S012345 Test\\Production\\Truck 12\\Programs\\INSULATION_XPS_2.5\\Nest 1\\TXT\\" "S0*")
Returns:
"S012345 Test"
; get_val function given path string and search pattern returns matching value
; Arguments:
; str = path string
; pat = string pattern
; Returns:
; found value
; (get_val "c:\\Autodesk\\Projects\\Category\\" "Pr*")
; Returns:
; "Projects"
; nil if none found
(defun get_val (str pat / aec_str2lst aec_vl-positionw idx lst val)
;;;--- aec_str2lst function
; splits given string with separator
; returns list with each item
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-do-i-split-a-file-path-into-bits-based-on-back-slash/td-p/2396237
; Usage:
; (aec_str2lst (findfile "acad.exe") "\\")
; Returns:
; ("C:" "Program Files" "Autodesk" "AutoCAD 2020" "acad.exe")
; Usage:
; (aec_str2lst "0 1 2 3" " ")
; Returns:
; ("0" "1" "2" "3")
(defun aec_str2lst (str sep / pos)
  (if (setq pos (vl-string-search sep str))
   (cons (substr str 1 pos)
    (aec_str2lst (substr str (+ (strlen sep) pos 1)) sep)
   (if(not(zerop(strlen str)))(list str))
) ; defun
;;;--- aec_vl-positionw function given wildcard expression and list returns index with position match
; Arguments:
; exprw = expression with wildcard
; lst = list
; Usage:
; (aec_vl-positionw "*acad*" '("This is Autodesk" "That is not Revit" "Now is acad"))
; Returns:
; 2
(defun aec_vl-positionw (exprw lst / i j)
 (setq i 0)
 (while (< i (length lst))
  (if (wcmatch (nth i lst) exprw)
   (progn
    (setq j i) ; wildcard match found
    (setq i (length lst)) ; stop looping
  ) ; if match
  (setq i (1+ i)) ; continue to next item
 ) ; while list items
 j
) ; defun
 (if(setq lst(aec_str2lst str "\\"))
   (if(setq idx (aec_vl-positionw pat lst))
     (setq val(nth idx lst))
   ) ; if
 ) ; if
 val
) ; defun get_val
Paul Li
IT Specialist
@The Office
Travis.Biddle
this works great, but how can I call this out in a program and set a variable of the results?
Setq XX (results of running Get_Val on dwgprefix variable)
XX = "S012345 Test"
paullimapa
Simple:
(setq xx (get_val "C:\\Users\\trab01\\Box\\AX Projects\\S012345 Test\\Production\\Truck 12\\Programs\\INSULATION_XPS_2.5\\Nest 1\\TXT\\" "S0*"))
You can even do a test to see if there's a value found:
(if (setq xx (get_val "C:\\Users\\trab01\\Box\\AX Projects\\S012345 Test\\Production\\Truck 12\\Programs\\INSULATION_XPS_2.5\\Nest 1\\TXT\\" "S0*"))
 (princ"Something")
 (princ"Nothing")
) ;if
Paul Li
IT Specialist
@The Office
Travis.Biddle
yes this works, but I want to pull it from the DWGPREFIX variable.  Something like..
(setq xx (get_val (getvar "dwgprefix”)))
or
(setq prefix  (getvar "dwgprefix"))
(setq xx (get_val prefix))
paullimapa
then just include (getvar "dwgprefix") as the first argument and still include the second argument which is the matching pattern "S0*":
(setq xx (get_val (getvar "dwgprefix") "S0*"))
Paul Li
IT Specialist
@The Office
Travis.Biddle
Ahh, I see.  Thank you so much!!
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Sea-Haven
Maybe I am missing something. This finds 5th directory.
; thanks to Lee-mac for this defun
; www.lee-mac.com
; 44 is comma 9 is tab 34 is space 92 backslash
(defun _csv->lst ( str / pos )
	(if (setq pos (vl-string-position 92 str))
		(cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
		(list str)
(setq ans (_csv->lst (getvar 'dwgprefix)))
; use (nth x ans) and look for the item you want
(setq dir (nth 4 ans))
ВeekeeCZ
Another way. Search for "\S0", cut the string from there to the following "\".
(defun :projectnumber (path / start)   ;; returns "" if \\S0 not found
  (if (wcmatch path "*\\S0*")
    (substr path
	    (setq start (+ (vl-string-search "\\S0" path) 2))
	    (1+ (- (vl-string-position (ascii "\\") path start) start)))
;; Usage
(:projectnumber (getvar 'dwgprefix))
Travis.Biddle
Very nice!!  This helps me in other things as well.  Thank you very much!
