Help Page for Developers is Missing in AutoCAD 2018 Vanilla
mgorecki
mgorecki
In 2015, I was able to pick Help (F1) and select "Developer Home Page" from the list under Resources.
In AutoCad 2018 (Mechanical) Vanilla, it is missing from the page.
Is there a way I can add it to a pull down?
I also tried Help > Additional Resources > Developer Help and got the same help page as before.
Mark
pendean
Community Legend
Community Legend
In R2019 On the Help home page, under Resources, click Developer Documentation.
Sea-Haven
Sorry to hijack but there appears to be a problem at Autodesk if you google a VL command and it suggests a Autodesk page as solution it comes back as "Not Found" this has just happened maybe a week ago ?
Anybody else having same problem ?
cadffm
Google is not an Autodesk product, so what is the problem?
And.. it w8rks without a problem, so long you try to follow a link to the help,
but a lot of topics in the AKN moved.
And of you use google, you can edit your search to filter for the forum or the help.
I prefer the help to use directly.
https://help.autodesk.com/view/OARX/2020/ENU/
Sebastian
mgorecki
I don't have that option under Resources.
ambrosl
The Developer Documentation link is present on the AutoCAD 2018 Help homepage (https://help.autodesk.com/view/ACD/2018/ENU/), but not present on the AutoCAD Mechanical 2018 Help homepage (https://help.autodesk.com/view/AMECH_PP/2018/ENU/).
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
