Help needed - Duplicate existing layouts, rename them to xxx-Suffix from a predefined list, and VPFreeze layers other than the layer containing corresponding suffix.
PkostrzewaM3SXC
Message 1 of 21
PkostrzewaM3SXC
Hello everyone,
I'm trying my best to use my limited knowledge about lisp routines and create a lisp routine that would make my life a lot easier but I'm failing miserably.
I attempted combining some of the lisp routines that I found on this forum with no success and at this point I feel like I don't know what to try anymore.
The routine I need would do the following:
For every existing layout in the drawing it would generate multiple identical layouts with specified suffixes.
I assume it would be some sort of a list at the beginning of the routine.
Then in these layouts a viewport freeze action would be performed on all the layers other than the layer containing the suffix.
Could you guys guide me a bit or help me out please?
Thank you!
Replies (20)
Message 2 of 21
hmsilva
@PkostrzewaM3SXC
This is quick and dirty, and minimally tested, but it may get you started:
(defun c:demo (/ i lay layt_lst lay_lst lay_n n new_layt suf_lst)
  (setq suf_lst '("123-" "456-"));; <<< suffixes from a predefined list
  (setq layt_lst (layoutlist))
  (setq lay (tblnext "LAYER" T))
  (while lay
    (setq lay_n (cdr (assoc 2 lay)))
    (foreach suf suf_lst
      (if (wcmatch lay_n (strcat suf "*"))
	(setq lay_lst (cons (cons suf lay_n) lay_lst))
    (setq lay (tblnext "LAYER"))
  (setq lay_lst (reverse lay_lst))
  (setq n (length lay_lst))
  (foreach layt	layt_lst
    (setq i 0)
    (while (< i n)
      (setq new_layt (strcat (car (nth i lay_lst)) layt))
      (command "-layout" "_C" layt new_layt)
      (setvar 'CTAB new_layt)
      (command "_.mspace")
      (command "_.vplayer" "_t" "*" "" "")
      (setvar 'CLAYER (cdr (nth i lay_lst)))
      (command "_.vplayer" "_f" "*" "" "_t" (cdr (nth i lay_lst)) "" "")
      (command "_.pspace")
      (setvar 'CTAB "Model")
      (setq i (1+ i))
  (princ)
Hope this helps,
Henrique
Message 3 of 21
Sea-Haven
Nice solution maybe rather than coding list read a csv file, pretty easy to make using excel etc.
Message 4 of 21
PkostrzewaM3SXC
Thank you @hmsilva .
I tried loading it as a lisp and nothing happens when I execute the command.
I will try to play around and see what's going on - at the moment it does not indicate what might be wrong - the command line stays empty after executing.
Any ideas why?
Thank you again for a prompt response !
Kind regards,
Patrick
Message 5 of 21
hmsilva
Agree!
The OP as stated "I'm trying my best to use my limited knowledge about lisp routines and create a lisp routine"
and I just wrote it in the simplest way I could, to be more understandable to the OP.
It could have been written to read a file, without command calls and to reorder the tabs at the end, but it wouldn't be so easy to understand...
Henrique
Message 6 of 21
hmsilva
Any ideas why?
Kind regards,
Patrick
@PkostrzewaM3SXC
in this line
you will have to change '("123-" "456-") to the correct sufixes
If you can't, share with us the sufixes list, so we can change the code
Hope this helps,
Henrique
Message 7 of 21
PkostrzewaM3SXC
That was the first thing I did - nothing happened.
Then I started doubting myself and I used the ones you used to see if it will throw an error - still nothing
Message 8 of 21
hmsilva
Share with us a dwg
Henrique
Message 9 of 21
PkostrzewaM3SXC
I attach the drawing I tested it in.
The suffixes im trying to use are Gas, Water etc. Basically all of the layers that end with *Rte - GasRte , WaterRte etc.
Message 10 of 21
hmsilva
If layer is "Pr_70_75_72-TrafficManageRte"  and layout "46599-01A" what would be the new layout name?
Henrique
Message 11 of 21
PkostrzewaM3SXC
46599-01A-Traffic
Message 12 of 21
hmsilva
46599-01A-Traffic
This is not easy for me, because I would have to know all the keywords to compare with the layer names...
One option is to remove everything to the last "-" and "Rte" from the layer name, would be left "TrafficManage".
I'll have to leave the office, but when I come back I'll change the demo to work in that way
It would be ok for you?
And by the way, it's not a prefix, it's a suffix
Henrique
Message 13 of 21
hmsilva
Revised...
(defun c:demo (/ i lay layt_lst lay_lst lay_n n new_layt)
  (while lay
      (if (wcmatch lay_n "*Rte")
	(setq lay_lst (cons lay_n lay_lst))
    (setq i 0)
    (while (< i n)
      (setq lay_n (nth i lay_lst))
      (setq lay_n (vl-string-right-trim "Rte" lay_n))
      (setq new_layt (strcat layt "-" (substr lay_n (+ 2 (vl-string-position (ascii "-") lay_n nil T)))))
      (setvar 'CLAYER (nth i lay_lst))
      (command "_.vplayer" "_f" "*" "" "_t" (nth i lay_lst) "" "")
      (setq i (1+ i))
  (princ)
Hope this helps,
Henrique
Message 14 of 21
PkostrzewaM3SXC
I really appreciate your help @hmsilva
Preferably I would want the layers to stay the way they are, but if there is no way around it at this point then I'll take it 🙂
Message 15 of 21
PkostrzewaM3SXC
Wow that's amazing!
There is no way I could've done it myself.
Where are you based @hmsilva ? Can I get you something as a thank you?
Message 16 of 21
hmsilva
Wow that's amazing!
Thank you, it is enough...
I'm in Portugal.
Glad I could help
Henrique
Message 17 of 21
PkostrzewaM3SXC
Thank you @hmsilva
You are a star 🙂
Message 18 of 21
hmsilva
Thank you @hmsilva
You are a star 🙂
You're welcome, @PkostrzewaM3SXC
Henrique
Message 19 of 21
PkostrzewaM3SXC
Sorry to bother you again @hmsilva
The routine seems to be cutting letters R E and T from the words before the "Rte" itself but not in all cases - Water for example stays as it should.
I can see that the routine is set to trim the string for "Rte" but nothing other than this
Any ideas as to why it is doing it?
Message 20 of 21
hmsilva
Change
to
(setq lay_n (substr lay_n 1 (- (strlen lay_n) 3)))
Hope this helps,
Henrique
