Help. LISP Create polyline from location end of lines
daohaquang
daohaquang
Previously I have a topic about Draw Line from justify of the Text. Now I want to add a command to create a polyline from location end points of the line like in the image. Help me. Sorry for using Google translate.434343.JPG
ВeekeeCZ
(defun c:PLends ( / l)
  (and (setq l (ssget '((0 . "LINE"))))
       (setq l (vl-remove-if 'listp (mapcar 'cadr (ssnamex l))))
       (setq l (mapcar '(lambda (e) (cdr (assoc 11 (entget e)))) l))
       (setq l (vl-sort l '(lambda (p q) (< (car p) (car q)))))
       (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length l)) '(70 . 0) '(62 . 1))
			(mapcar '(lambda (p) (cons 10 p)) l))))
  (princ)
daohaquang
Thank you so much, You are pro
I have one more small problem, I want 1 lisp to export the line length to text.
1. Select line (pline)
2. Export to existing text
Can you help me?
hak_vz
@daohaquang  Something like this?
(defun c:lengthToText ( / le lo te to)
	(cond
		((and (setq le (car(entsel "\nSelect entity to extract length >"))))
			(setq lo (vlax-ename->vla-object le))
			(cond
				((vlax-property-available-p lo 'Length )
					(cond
						((and(setq te (car(entsel "\nSelect text to write length >"))))
								(setq to (vlax-ename->vla-object te))
								(vlax-put to 'TextString  (rtos (vlax-get lo 'Length) 2 3))
Miljenko Hatlak
pbejse
(Defun c:LFDTJ (/ ss i e data p val l ep pl te )
  (if (setq l  nil
	    ss (ssget '((0 . "TEXT") (1 . "*#.#*")))
    (progn
      (repeat (setq i (sslength ss))
	(setq e (ssname ss (Setq i (1- i))))
	(setq data (mapcar '(lambda (dx)
			      (cdr (assoc dx (entget e)))
			   '(10 11 1 8)
	(and (numberp (setq val (read (Caddr data))))
	     (entmakex (list (cons 0 "LINE")
			     (cons 8 (last data))
			     (cons 10
				   (setq p (if (vl-every 'zerop (Cadr data))
					     (car data)
					     (cadr data)
			     (cons 11 (setq ep (polar p (/ pi 2.0) val)))
	     (setq l (cons ep l))
      (and
        (setq pl (entmakex (append (list '(0 . "LWPOLYLINE")
			     '(70 . 0)
			     '(62 . 1))
	(setq te (car (entsel "\nSelect text to write length >")))
	(setpropertyvalue te "Textstring" (rtos (getpropertyvalue pl "Length") 2 3)))
  (princ)
HTH
daohaquang
Sorry I just need LISP Create polyline from location end of lines, and lisp export the line length to text is another lisp, I had lisp export the line length to text, You can repair you lisp to "Draw Line from justify of the Text" and "Create polyline from location end of lines" and remove "export the line length to text".
Thank so much
ВeekeeCZ
Post 2 dwgs. Before and after to clearly see what you want.
