Help in lisp for bind dwg
cool.stuff
cool.stuff
Hello 🙂
I am trying to code a lisp to bind xrefs of several dwgs.
My code is this:
(defun c:XBD ()
  (setvar "FILEDIA" 0)
  (setvar "SDI" 1)
  (setq dwgl (LM:directoryfiles "C:\\Users\\usr\\Desktop\\New folder" "*.dwg" nil))
  (foreach dwg dwgl
    (c:PD dwg)
  ;(setvar "FILEDIA" 1)
  ;(setvar "SDI" 0)
  (princ)
(defun LM:directoryfiles ( dir typ sub )
  (setq dir (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir)))
  (append
    (mapcar '(lambda ( x ) (strcat dir "\\" x))
            (vl-directory-files dir typ 1))
    (if sub
      (apply 'append
        (mapcar
          '(lambda ( x )
             (if (not (wcmatch x "`.,`.`."))
               (LM:directoryfiles (strcat dir "\\" x) typ sub)))
          (vl-directory-files dir nil -1))))))
(defun c:PD (dwgp)
  (command "_.OPEN" dwgp)
  (foreach ln (layoutlist)
    (c:PLN ln)
  ;(setvar "SDI" 0)
  (c:DP dwgpath)
  (command "_.close" "y")
  (c:CP)
(defun c:PLN (LN)
  (cond
	((or (= LN "Layout2") (= LN "Layout1"))
	 (command "-LAYOUT" "_d" LN)
    (T
(defun c:CP ( / )
  (setvar "PUBLISHALLSHEETS" 0)
  (setvar "CMDDIA" 0)
  (command "_.PUBLISH")
  (setvar "CMDDIA" 1)
(defun c:DP (dwgpath)
	(command "_purge")
    (command "_.QSAVE")
    (command "_.CLOSE")
My current issues:
- I do know how to delete unreferenced or missing xref's for each drawing;
- I cannot make publish command work (using the current settings);
- I cannot make it work for all files. Once it opens the first file. it stops.
Also it only works on a blank project without changes...
Can someone help me please?
Many thanks 🙂
Moshe-A
@cool.stuff  hi,
can not see any binding xrefs in your code?
My current issues:
you mean manually?
AutoLISP exist/works in an open drawing/editing session, as soon as you close drawing, there is no AutoLISP (your lisp program break)
to run a lisp command on a list of drawings you need to create a script file (.scr) to be run from outside AutoCAD or better use
 >> ScriptPro 2 <<  open each dwg run some lisp commands (like bind xrefs + plot to pdf) save and close (publish is more
designed to work manually and not be called from lisp).
Moshe
cool.stuff
@Moshe-Ahello,
thanks for you answer.
sorry, I pasted an older attempt of my code.
And I have a typo in my post:
"(command "-xref" "b" "*")"
and I do not know how to bind all xrefs, deleting the unreferenced and missing ones.
Also, I do not know how to use the publish command in a lisp, using the current settings.
Thanks again 🙂
Moshe-A
@cool.stuff ,
Why do you want to bind all xrefs? share your reasons and how binding xrefs is related to plotting?
i think you should separate these tasks cause in each of these task there are potential of errors
that will break your batch.
Moshe
cool.stuff
@Moshe-Athanks for your reply.
Ok, I will create 2 scripts for these tasks.
I have manage to create a script as you recommended.
Binding all xrefs is a normal need when publishing to dwg files (at least where I work).
Then, I need to publish all drawings. I have configured publish options but I dont know how to use this command to consider each layout current settings in a script. I need to publish to PDF, DWG and DWF.
Could you give me an example how to achieve this please?
Moshe-A
@cool.stuff ,
Sorry but i do not understand this:-
say i have a drawing hosting some xrefs and i publish it pdf
then i have the same drawing all xrefs are bind and publish it pdf
do i get a different printed pdfs?!
The standard PUBLISH is so strong and has many options for printing a list of drawings from model space and layouts,
it is automation by it self and i do not see any room to write a lisp to do better job.
Moshe
