Help in editing a LISP
Message 1 of 13
I found a Lisp here in the forum and I can not edit it, lisp works as follows, it exports the X, Y, Z coordinates of a Polyline and transforms it into a .txt file, except I do not want it to export the polyline , but rather a clickable place of instead of selecting the polyne to be the coordinate of the point that I clicked, Ex: I clicked at any point it generates the XYZ coordinates of the point that I clicked.
(defun ERR (S)
(if (= S "Function cancelled")
(princ "\nVERTEXT - cancelled: ")
(progn (princ "\nVERTEXT - Error: ") (princ S) (terpri)) ;_ progn
) ;_ if
(RESETTING)
(princ "SYSTEM VARIABLES have been reset\n")
(princ)
) ;_ err
(defun SETV (SYSTVAR NEWVAL)
(setq X (read (strcat SYSTVAR "1")))
(set X (getvar SYSTVAR))
(setvar SYSTVAR NEWVAL)
) ;_ setv
(defun SETTING ()
(setq OERR *ERROR*)
(setq *ERROR* ERR)
(SETV "CMDECHO" 0)
(SETV "BLIPMODE" 0)
) ;_ end of setting
(defun RSETV (SYSTVAR)
(setvar SYSTVAR (eval X))
) ;_ restv
(defun RESETTING ()
(RSETV "CMDECHO")
(RSETV "BLIPMODE")
(setq *ERROR* OERR)
) ;_ end of resetting
(defun DXF (CODE ENAME) (cdr (assoc CODE (entget ENAME)))) ;_ dxf
(defun VERTEXT (/ EN VLIST)
(setq EN (GET-EN))
(if (= (DXF 0 EN) "LWPOLYLINE")
(setq VLIST (GET-LWVLIST EN))
(setq VLIST (GET-PLVLIST EN))
) ;_ if
(WRITE-IT VLIST EN)
) ;_ vertext
(defun GET-EN (/ NO-ENT EN MSG1 MSG2)
(setq NO-ENT 1
EN NIL
MSG1 "\nSelect a polyline: "
MSG2 "\nNo polyline selected, try again."
) ;_ setq
(while NO-ENT
(setq EN (car (entsel MSG1)))
(if (and EN
(or (= (DXF 0 EN) "LWPOLYLINE") (= (DXF 0 EN) "POLYLINE")) ;_ or
) ;_ and
(progn (setq NO-ENT NIL)) ; progn
(prompt MSG2)
) ;_ if
) ;_ while
EN
) ;_ get-en
(defun GET-LWVLIST (EN / ELIST NUM-VERT VLIST)
(setq ELIST (entget EN)
NUM-VERT (cdr (assoc 90 ELIST))
ELIST (member (assoc 10 ELIST) ELIST)
VLIST NIL
) ;_ setq
(repeat NUM-VERT
(setq VLIST (append VLIST (list (cdr (assoc 10 ELIST)))) ; append
) ;_ setq
(setq ELIST (cdr ELIST)
) ;_ setq
) ;_ repeat
VLIST
) ;_ get-lwvlist
(defun GET-PLVLIST (EN / VLIST)
(setq VLIST NIL
EN (entnext EN)
) ;_ setq
(while (/= "SEQEND" (DXF 0 EN))
(setq VLIST (append VLIST (list (DXF 10 EN))))
(setq EN (entnext EN))
) ;_ while
VLIST
) ;_ get-plvlist
(defun WRITE-IT (VLST EN / NEWVLIST MSG3 FNAME)
(setq NEWVLIST (mapcar '(lambda (X) (trans X EN 0)) ;_ lambda
VLST
) ;_ mapcar
MSG3 "Polyline vertex file"
FNAME (getfiled MSG3 "" "txt" 1)
F1 (open FNAME "w")
) ;_ setq
(WRITE-HEADER)
(WRITE-VERTICES NEWVLIST)
(setq F1 (close F1))
) ;_ write-it
(defun WRITE-HEADER (/ STR)
(setq STR " POLYLINE VERTEX POINTS")
(write-line STR F1)
(setq STR (strcat " X " " Y " " Z") ;_ strcat
) ;_ setq
(write-line STR F1)
) ;_ write-header
(defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR)
(foreach ITEM NEWVLIST
(setq XSTR (rtos (nth 0 ITEM) 2 4)
YSTR (rtos (nth 1 ITEM) 2 4)
ZSTR (rtos (nth 2 ITEM) 2 4)
STR (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR) ;_ strcat
) ;_ setq
(write-line STR F1)
) ;_ foreach
) ;_ write-vertices
(defun SPACES (STR / FIELD NUM CHAR SPACE)
(setq FIELD 15
NUM (- FIELD (strlen STR))
CHAR " "
SPACE ""
) ;_ setq
(repeat NUM (setq SPACE (strcat SPACE CHAR))) ;_ repeat
) ;_ spaces
(defun C:VTX ()
(SETTING)
(VERTEXT)
(RESETTING)
(princ)
) ;_ c:vtx
(prompt "\nEnter VTX to start")
Accepted solutions (3)
Replies (12)
Message 2 of 13
hanslammerts
What do you mean 'can't edit it'?
save it as a .lsp file.
use the vlisp command to start vlide
Message 3 of 13
@hanslammertsThe problem is not the way to load, it is to edit the code to do what is described in the question.
Message 4 of 13
hanslammerts
Didn't read carefully, sorry
there are a whole bunch of progs that can work with xyz
like this one. No need to invent wheels over 😉
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=nl&ie=UTF-8&u=http%3A%2F%2Fwww....
Message 5 of 13
@hanslammerts
Excuses, but I do not think you understood the point. This software made available for download, does exactly what LISP described in the question, takes as coordinates of an existing object and exports the XYZ coordinates, BUT I do not want as coordinates of an object, but the coordinates of a click, EXAMPLE: A every Click that I give in autocad, be exported to the exact coordinate of that click.
Message 6 of 13
I'm from Brazil, and google does not translate correctly.
Message 7 of 13
john.uhden
I understand your english.
I presume you are going to pick a number of points in the same command function, si?
I presume you want each line to be comma-delimited, like a CSV file, ai?
To what precision do you want the values (places after the decimal)?
If you use the command later, do you want to maybe append to the previous file, or do you want a new file each time?
Do you want the file to be a CSV, or TXT, or you decide each time?
John F. Uhden
Message 8 of 13
john.uhden
Also...
Do you want to number the points as you pick them, like starting at 1 (or any number)?
Do you want to add a description?
For example:
#,X,Y,Z,Description
This is a typical format for survey points like you might send to a surveyor (usually via e-mail) for staking out points in the field.
John F. Uhden
Message 9 of 13
@john.uhden
###I presume you are going to pick a number of points in the same command function, si?
R: Exactly.
### I presume you want each line to be comma-delimited, like a CSV file, ai?
R: Can be
### To what precision do you want the values (places after the decimal)?
R: 4 places after the decimal
###If you use the command later, do you want to maybe append to the previous file, or do you want a new file each time?
R: I want to attach to the previous file
###Do you want the file to be a CSV, or TXT, or you decide each time?
R:  decide each time
###Also...
R:Yes, it's essential.
For example:
#,X,Y,Z
follows jpg dp example of how I would like it.
Message 10 of 13
john.uhden
Pardon me, but I haven't provided any solution as yet.
John F. Uhden
Message 11 of 13
joselggalan
try this:
;;============================= c:Test0007 ====================================;;
;; Jose L. García G. -  29/10/17                                               ;;
(defun c:Test0008 (/ p1 oFile sFile tmp Separator i
		     ;|Functions|; GetFormatFile aux:SelectFile grdx
	;;_________________________________________________
	(defun GetFormatFile (/ lsts)
	 (or *Format* (setq *Format* "csv"))
	 (setq lsts '(("csv" ";" "[<Csv>/Txt/Xls]")
		      ("txt" " " "[Csv/<Txt>/Xls]")
		      ("xls" "\t" "[Csv/Txt/<Xls>]")))
	 (setq mens (last (assoc *Format* lsts)))
	 (initget "Csv Txt Xls _csv txt xls")
	 (if (setq tmp (getkword (strcat "\nFormat file;" mens ": ")))
	  (setq *Format* tmp)
	 (setq Separator (cadr (assoc *Format* lsts)))
	(defun aux:SelectFile ( Extension / ff)
	 (if (setq ff (getfiled "Select File" (if *TmpRutaFile* *TmpRutaFile* "") Extension 1))
	  (setq *TmpRutaFile* (strcat (vl-filename-directory ff) "\\"))
	 );c.if
	 ff
	);c.defun
	; grdx - graphic cross utility
	(defun grdx (p col size / h)
	  (setq h (/ (getvar "viewsize") size))
	  (grdraw (list (- (car p) h) (- (cadr p) h))
	          (list (+ (car p) h) (+ (cadr p) h)) col 0)
	  (grdraw (list (- (car p) h) (+ (cadr p) h))
	          (list (+ (car p) h) (- (cadr p) h)) col 0)
	  p
	);c.defun
 ;;--------------------- MAIN -----------------
 (or *Prec* (setq *Prec* 4))
 (setq p1 (getpoint "\nPick first point: "))
 (while p1
  (grdX p1 213 125)
  (setq lstFile (cons p1 lstFile))
  (setq p1 (getpoint " >> Pick Next point: "))
 (cond
  (lstFile
   (initget (+ 4))
   (if (setq tmp (getint (strcat "\nPrecisión;<" (itoa *Prec*) ">: ")))
    (setq *Prec* tmp)
   (GetFormatFile)
   (setq sFile (aux:SelectFile *Format*))
   (cond
    (sFile
     (setq i 1)
     (setq oFile (open sFile "w"))
     (write-line "COORDINATES OF POINTS" oFile)
     (write-line (strcat "#" Separator "X" Separator "Y" Separator "Z") oFile)
     (mapcar
      (function
       (lambda (pt)
	(write-line (strcat (itoa i) Separator
			    (rtos (car  pt) 2 *Prec*) Separator
			    (rtos (cadr pt) 2 *Prec*) Separator
			    (rtos (last pt) 2 *Prec*)
	 oFile)
	(setq i (1+ i))
      lstFile
     );c.mapcar
     (close oFile)
     (alert (strcat "File: \n\n[" sFile "]\n\nhas been created."))
     ;;(startAPP (strcat "notepad.exe " sFile))
     (command "shell" (strcat "start " sFile))
 );c.cond
 (princ)
(princ)
regards...
Message 12 of 13
@joselggalan
Thank you very much, that's exactly what I was looking for.
Message 13 of 13
john.uhden
I think this will serves your purpose.
If you are creating a new file, it will start numbering the points at #1.
If you are appending to an existing file, it will read the file and start appending at the next higher number.
It saves the last file written or appended in the registry, which becomes the default file, but you can select/create a different file if you wish.
It writes the coordinates to 4 decimal places in the order of X, Y, Z, comma-delimited.
John F. Uhden
