Help in Customizing Lisp Code
clerigoaaron
Message 1 of 39
clerigoaaron
I have a Lisp code from a community member that compiles different pipe dxfs into 1 single file. It also inserts the pipes drawing number and pipe number as it is compiling. The data is extracted from an excel spread sheet and is cross referenced with the dxfs file name (also the drawing number). This Lisp only works if the data in the excel starts at Column A row 2. How can I change the code for it work even if the data starts at column B row 26? Thank you. Please see the code and excel below.
(Defun c:MakeThisHAppen ( /  _Entnext ExtractFromXls el moveAll fileName XL-App Workbooks exData f textObj moveAll)
(defun _Entnext ( e )
    (if (setq e (entnext e)) (cons e (_Entnext e)))
(defun ExtractFromXls (st app col / ncol val dataCollection)
      (repeat col
	(setq ncol (cons col ncol))
	(setq col (1- col))
       (while
	 (vl-every 'eval
		   (setq val
			  (mapcar '(lambda (i / cv)
				     (if (Setq cv (vlax-get-property (vlax-get (vlax-get app "ActiveSheet") 'Cells) 'Item st i))
                  			(vlax-variant-value
					  (vlax-get-property
					    (vlax-variant-value cv)
					    'Value
				     ) ncol)
	 (setq dataCollection (cons (mapcar 'vl-princ-to-string val) dataCollection))
	 (setq st (1+ st))
      dataCollection
(if (and
      		(setq  Directory (acet-ui-pickdir
				 "Select Project Folder" (if Directory Directory (getvar 'dwgprefix))))
      		(setq moveAll (ssadd)
		       dxfFiles (vl-directory-files directory "*.dxf" 1))
		(setq fileName (getfiled "Excel Spreadsheet File"
                                   (if fileName fileName (getvar 'dwgprefix))"XLSX;XLS" 16 ))
        	(setq XL-App    (vlax-get-or-create-object "Excel.Application"))
      		(Setq Workbooks (vlax-invoke-method (vlax-get-property XL-App 'WorkBooks)
                                    'Open  fileName ))
      		(setq exData (extractfromxls 1 XL-App 2))
  (progn
	(foreach fname dxfFiles
	  (if (Setq f (Assoc (strcase (vl-filename-base  fname)) exData))
		(progn
		  (setq el (entlast))
		  (command "_DXFIN" (strcat directory "\\" fname) '(0.0 0.0 0.0))
		  (if (null el)(and (setq el (entnext)) (ssadd el moveAll)))
		  (mapcar '(lambda ( x ) (ssadd x moveAll)) (_Entnext el))
		  (foreach strdata (list
				     '((0.0 0.0 0.0) 12 "Proj-123")
				     (list '(0.0 -30.00 0.0) 12
				       (strcat "Dwg no: " (vl-filename-base fname)
				     (list '(0.0 -45.0 0.0) 12 (strcat "Pipe no: " (Cadr f))
		  (setq textObj (entmakex (list (cons 0 "TEXT")
					    (cons 10 (car strdata))
					    (cons 40 (cadr strdata))
					    (cons 1 (caddr strdata))
		    (ssadd textObj moveAll))
		    (command "_move" moveAll "" "_non" "0,0,0" "0,500,0")
	    (princ (Strcat "\n" (vl-filename-base  fname) " Not found on source list"))
  		(vlax-invoke-method Workbooks 'close  fileName )
	    	(vlax-release-object XL-App)
		(vlax-release-object Workbooks)
  (Vl-some '(lambda (l)
	      (if (null (eval (Car l)))(print (cadr l))))
	   		'((Directory "No folder selected/Cancelled by user")
			  (dxfFiles "No DXF files found on selected folder")
			  (fileName "No xls:x;sx file found on selected folder / Cancelled by user")
			  (XL-App "Excel application not found")
  (princ)
Replies (38)
Message 2 of 39
Simon_Weel
This is the line where data is extracted from the Excel file:
As you can see, the function extractfromxls is called with three arguments: 1 XL-App 2. In the function itself represented by st app col. I guess st is the row number and col is the (starting?) column number.
Give it a try and change those numbers and see what happens?
Message 3 of 39
clerigoaaron
I changed it to 26 XL-App 2 and it works. Started extracting data at column A row 26. But following your instructions shouldnt this be column B row 26? I cant think of how to change the column part
Message 4 of 39
Sea-Haven
There was a contibutor no longer with us FIXO who did lots of stuff with Excel i have a few of his routines, one is to select a range and return that range as a List.
; Thanks to FIXO for get range
(defun getrangexl2 ( / lst UR CR RADD )
(vl-catch-all-error-p
	   (setq Rng
		  (vl-catch-all-apply
		    (function (lambda ()
				(vlax-variant-value
				  (vlax-invoke-method
				    (vlax-get-property myxl 'Application)
				    'Inputbox
				    "Select a Range: "
				    "Range Selection "
				    nil
				    nil
				    nil
				    nil
				    nil
				    8))))))
(setq xrng (vlax-get-property rng "address"))
(setq xxrng xrng)
(repeat 4 (setq xxrng(vl-string-subst "" "$" xxrng)))
(setq xxxrng (_csv->lst58 xxrng))
(setq rngst (columnrow (nth 0 xxxrng)) rngend (columnrow (nth 1 xxxrng)))
(setq *ExcelData@ nil )
(setq Row# (nth 1 rngst))
(repeat (+ (- (nth 1 rngend)(nth 1 rngst) ) 1)
(setq Data@ nil)
(setq Column# (nth 0 rngst))
(repeat (+  (- (nth  0 rngend)(nth 0 rngst) ) 1)
(setq Range$ (strcat (Number2Alpha Column#)(itoa Row#)))
(setq ExcelRange (vlax-get-property myxl "Range" range$))
(setq ExcelVariant (vlax-get-property ExcelRange 'Value))
(setq ExcelValue (vlax-variant-value ExcelVariant))
(setq Data@ (append Data@ (list ExcelValue)))
(setq Column# (1+ Column#))
(setq *ExcelData@ (append *ExcelData@ (list Data@)))
(setq Row# (1+ Row#))
(princ)
The answer is in the variable  *ExcelData@
You need to change the myxl to your application name variable.
Message 5 of 39
pbejse
This code looks familiar.
This would be an easy tweak.
Message 6 of 39
clerigoaaron
Thats because is your code @pbejse I've been trying to study it for a while now but its so hard because I am starting from the basics
Message 7 of 39
ec-cad
In the code, I think 'st is short for 'St arting Row', and col is Column
Just guessing, Columns probably  A=2, B=3 from what you are getting.
So try 26  XL-App 3
ECCAD
Message 8 of 39
clerigoaaron
@ec-cad i tried that at it did not work. No error message show just nothing happened after running the lisp
Message 9 of 39
ec-cad
OK,
I'll look into it, be back later.
ECCAD
Message 10 of 39
ec-cad
OK,
I think I have a fix. Seems the 2 on the end is # of Columns, not position of Column.
Try these changes:
Change this:
To be:
(defun ExtractFromXls (st app col n / ncol val dataCollection)
.. added a n as 4th variable
And:
Change this:
To be:
(if (Setq cv (vlax-get-property (vlax-get (vlax-get app "ActiveSheet") 'Cells) 'Item st (+ i n)))
To get Row 26 and Column B, do:
(setq exData (extractfromxls 26 XL-App 2 1))
Seems like the first 2 is the # of Columns, not the 'index' to Column B
Added the n to the Function, to allow spefifying 'which' Column
where: n= 0 = A, 1 = B, 2 = C
Preliminary test shows:
Test 1 with Col 1
EXDATA=((04 15) (03 14) (02 13.0) (21.0 12R) (2BR 12L))
And, note: you need the Excel Cells formatted as 'text'
ECCAD
Message 11 of 39
clerigoaaron
@ec-cad @It worked as intended, the data extraction started at column B row 26. But for some reason it only worked until pipe 10. Pipes 11 onwards showed erro
Message 12 of 39
ec-cad
What was the error ?
ECCAD
Message 13 of 39
ec-cad
If I recreated the xlsx file correctly,
And using: (setq exData (extractfromxls 26 XL-App 2 1)); Column B
This is what's in exData list:
((28.0 25.0) (27.0 24.0) (26.0 23.0) (25.0 22.0) (24.0 21.0) (13.0 13.0) (11 11) (10R 10) (10L 10) (09R 9) (09L 9) (08R 8-1,8-2,8-3,8-4) (08L 8-1,8-2,8-3,8-4) (07R 7-1,7-2,7-3,7-4,7-5) (07L 7-1,7-2,7-3,7-4,7-5) (06R 6) (06L 6) (05 5))
Looks like that's (not) the problem.
Try doing a DXFIN of 10R, 10L, 11 & 12 one at a time, see if there's an issue with one of those .dxf's ?
ECCAD
Message 14 of 39
clerigoaaron
@ec-cad Here is the error message. im not sure why it only appears for 11 onward. They all have the same property in excel
Message 15 of 39
ec-cad
Hmm,
That's interesting. What's in the variable  'dxfFiles' ??
Do a !dxfFiles at the Command Line, or (princ dxfFiles) to see what's in there.
It (should) contain a list of all the .dxf files in the folder chosen.
If that contains all the .dxf's, then I don't have a clue... why some work and the
others do not.
ECCAD
Message 16 of 39
clerigoaaron
@ec-cad same I am stumped. It does contain all dxf files
Message 17 of 39
clerigoaaron
Testing another set of data. Everything was generated except pipe 24. I checked the individual dxf and everything even the excel properties of the cell. I cant think of any reason why #24 was the only one missing. Also no error code for this it just somehow skipped it. But trying the lisp on 24 only showed again the error of not being on the source list.
Message 18 of 39
ec-cad
In looking at the code again, I don't see an issue that would cause a random misfire.
However, potential exists for these lines that use 'f' for a variable name. F is usually reserved
for 'False.
So try changing these (3) lines to be 'fil' rather than 'f' alone.
1. (Defun c:MakeThisHAppen ( / _Entnext ExtractFromXls el moveAll fileName XL-App Workbooks exData f textObj moveAll)
2. (if (Setq f (Assoc (strcase (vl-filename-base fname)) exData))
3. (list '(0.0 -45.0 0.0) 12 (strcat "Pipe no: " (Cadr f))
ECCAD
Message 19 of 39
ec-cad
One other way might be to change:
(if (setq fil (Assoc (strcase (vl-filename-base fname)) exData))
To be:
(if (member (strcase fname) exData)
Try that.
ECCAD
Message 20 of 39
clerigoaaron
@ec-cad changing f to fil gave the same result of missing dxf files. Error says "not found in source list".
Using the (if (member (strcase fname) exData) resulted in all dxfs having error of "not found on source list"
