Help for Hatch
Help for Hatch
pullstackautocad
Message 1 of 10
Help for Hatch
pullstackautocad
I have a hatch pattern; can you help me create four separate hatches all for the origin?
0,0,0,0,1200,1100,-100
0,0,1100,0,1200,1100,-100
90,0,0,0,1200,1100,-100
90,1100,0,0,1200,1100,-100
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
What are the differences between the four that you wish to create?
Message 3 of 10
pullstackautocad
No, differences sir..  pattern is same.. i just want form all the four corners origin
Message 4 of 10
pendean
Community Legend
Community Legend
Hatch origins (four corners as you asked) are not controlled in the pattern definition, it's a setting inside your DWG file instead: is that what you are asking for?
https://www.youtube.com/watch?v=DTukpo3aym8
Message 5 of 10
Kent1Cooper
If I understand correctly what you're after, just use rotation to make the different origins.  As defined, at zero rotation, your pattern is generated from [has its origin at] the Lower Left corner of one of the squares it draws.  Just use 90° rotation for it to be generated from the Lower Right corner, 180° rotation for Upper Right, and 270° rotation for Upper Left.
Kent Cooper, AIA
Message 6 of 10
pullstackautocad
Thankyou sir it worked....
Message 7 of 10
pullstackautocad
@Kent1Cooper sir i have a question. why does my hatch doesnot work in template file cad file..
i dont understand it doesnot work . it open up autocad text window, it shows pick internal point and autocad gets hang
Message 8 of 10
Kent1Cooper
I had it working yesterday, but today it's showing as solid, even though Properties and the ribbon say it's the right pattern name, and the pattern thumbnail looks right, and I double-checked that at the scale used, it should be showing the squares.  [But AutoCAD is not hanging, for me.]
BUT IF YOU'RE WILLING TO DO IT THIS WAY, I find that if I put that definition into ACAD.PAT itself, or perhaps for you ACADISO.PAT, and not in a file of its own, then it works fine.  Normally I would prefer to avoid putting custom patterns into AutoCAD's file, because transferring to new versions is easier if they are kept separate.  But if it works, and nothing else does....
Kent Cooper, AIA
Message 9 of 10
pullstackautocad
i tired defining it on acad.pat but if i  select my hatch it atuomatically change into asi hatch . oh god i dont know how it works.
Message 10 of 10
Kent1Cooper
[Does "asi hatch" mean one of the ANSI... patterns?]
If you added the pattern definition at the end of ACAD.pat, make sure there's a blank line at the end of the file, below the last line of the pattern definition.
If that doesn't fix it, it may help to save the .pat file, close out of AutoCAD completely, and restart AutoCAD.
Kent Cooper, AIA
