help cui custoization. and a menu
i attached the zipped file i obtained from eaton. they have some short instruction for using 2002 autocad but i guess they arent going to update it. but the file use to create a menu you can choose valve type and then the symbol you want. how can i do that now. any help would be appreciated.
im using autocad 2020
hak_vz
Use this link to read how to import .MNU to transfer MNU file to .CUIX.  - Eaton2002(Dec05). After you follow the procedure you will have Eaton2002(Dec05).cuix generated in folder you are loading symbols.
Load .cuix file to menues and than add your folder location to supported file search path (tools ->options->files). That's it.
Miljenko Hatlak
The Kay there are 2 files in this download one labeled .mnu and another folder full of a bunch of .dwg files I was able to get the mnu converted and actually show the menu and everything but nothing was in it. Like where you would click what you want it didn’t have anything but all the menu sections were there. How do I attach the .dwg files to it. Or do I have to do something to these files first I did add the folder to the options file path you mentioned also. Sorry for being so lost but this is literally my second day ever touching autocad
Okay it work now I guess I may just have done something wrong but it’s good now. Thank you
hak_vz
OK
Miljenko Hatlak
