help Crete lisp
help Crete lisp
chan230984
Message 1 of 9
help Crete lisp
chan230984
Hi, all .
help Create lisp please, i want to click POLYLINE and get NE and sent to Excel or Notepad
thanks
Replies (8)
Message 2 of 9
dlanorh
Try this.
(defun rh:sammlung_n (o_lst grouping / tmp n_lst)
	(setq n_lst nil)
	(if (= (rem (length o_lst) grouping) 0)
		(while o_lst
			(while (< (length tmp) grouping)
				(setq tmp (cons (car o_lst) tmp)
							o_lst (cdr o_lst)
				);end_setq
			);end_while
			(setq n_lst (cons (reverse tmp) n_lst)
						tmp nil
			);end_setq
		);end_while
		(princ "\nModulus Error : The passed list length is not exactly divisible by the group size!!")
	);end_if
  (reverse n_lst)
);end_defun
(defun c:gpc ( / obj o_type c_lst t_file fp )
	(setq obj (vlax-ename->vla-object (car (entsel "\nSelect Polyline : "))))
  (cond ( (wcmatch (setq o_type (vlax-get-property obj 'objectname)) "*Polyline")
          (setq n (if (wcmatch o_type "*3d*") 3 2)
                c_lst (rh:sammlung_n (vlax-get obj 'coordinates) n)
                t_file (vl-filename-mktemp "Polyline" (getvar 'dwgprefix) ".csv")
                fp (open t_file "w")
          );end_setq
          (foreach v c_lst
            (setq p_str (strcat "N=" (rtos (cadr v) 2 3) ", E=" (rtos (car v) 2 3)))
            (write-line p_str fp)
          );end_foreach
          (close fp)
        ( (alert "Not a Polyline"))
  );end_cond
);end_defun
Type gpc to run
I am not one of the robots you're looking for
Message 3 of 9
chan230984
When select Polyline:
Command: (LOAD "C:/Users/CHAN/Desktop/sammlung_n.LSP") C:GPC
Command: GPC
Select Polyline : nil
Command:
Message 4 of 9
dlanorh
sammlung_n is the name of a subroutine to sort the coordinates into a list
Copy code, past into notepad and save to file somewhere in your autocad path. You choose the filename.
Command: APPLOAD <enter>
Navigate to where you saved the file, select and press load button. Press the close button.
Command : gpc <enter>
Should ask you to select a polyline. Creates a csv file in the same directory as the drawing. Double click this file and it will open in Excel
Link to detailed explanation - http://www.lee-mac.com/runlisp.html
Message 5 of 9
chan230984
Yes it's
when i Command : gpc <enter> and select Polyline
Command :
Message 6 of 9
dlanorh
That is correct.
Go to drawing folder and look for "polyl###.csv" file. Double click and it will open in excel.
Message 7 of 9
chan230984
Hi @dlanorh
Help me a little more
I want the E value in front of N
THANK YOU '
Message 8 of 9
dlanorh
	(setq n_lst nil)
		(while o_lst
							o_lst (cdr o_lst)
				);end_setq
			);end_while
						tmp nil
			);end_setq
		);end_while
	);end_if
  (reverse n_lst)
);end_defun
          );end_setq
          (foreach v c_lst
            (setq p_str (strcat "E=" (rtos (car v) 2 3) ", N=" (rtos (cadr v) 2 3)))
          );end_foreach
          (close fp)
  );end_cond
);end_defun
As requested. Enjoy. Robot Happy
Message 9 of 9
chan230984
@dlanorh  Thanks again
