Help change color to background
Jonathan3891
Advisor Advisor
Jonathan3891
I have a lisp that will add a background mask to mtext and sets the color to 250.
I need to the lisp to set the color to the background color, like if I were to manually do it and select "use drawing backround color".
Thanks for the help!
DSM_Dude
(defun c:mblank ( / js n dxf_ent)
	(setq js (ssget '((0 . "MTEXT"))))
	(cond
		(js
			(repeat (setq n (sslength js))
				(setq dxf_ent (entget (ssname js (setq n (1- n)))))
				(entmod (append dxf_ent '((90 . 1) (63 . 250) (45 . 1.1) (441 . 0))))
Jonathan Norton
Blog | Linkedin
hmsilva
Try
(90 . 3) (63 . 256)
Henrique
Jonathan3891
Thank You!!
I tried changing the color to 256 but it would always make the background color match the color of the text.
Jonathan Norton
Blog | Linkedin
hmsilva
You're welcome
Henrique
