Help calling geomcalc from lisp
Message 1 of 11
Hello Everyone,
I have a line in a lisp the uses the calculator.
(setq pt5 (c:cal
"plt(pt2,pt3,0.5)"))
If I manually load the "cal" before I run it, it works. If I don't I get
this
error;
.*** ERROR : too many arguments
So I put (arxload "c:/program files/ACAD2000/geomcal.arx") in the
acad2000.lsp
file to be sure it was loaded.
Now everytime I open another drawing I see "arxload failed" (because its
already
loaded). Can someone tell me the proper way to handle this?
Randy
Replies (10)
Message 2 of 11
Mr. Smeghead,
Personally, I would not rely upon the command line calculator. LISP is rich
with calculations within itself that should be sufficient for what you are
trying to do.
Eugene N. Kilmer
Owner/Mag Drafting
Message 3 of 11
Hi, Smeghead
I'm using similar lisp routine and it works well.
Please see bellows.
I'm sure this is what you looking for.
;;;;;; Loading "geomcal.arx" ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun Load_cal ( / file_dia)
(if (not cal)
(progn
(setq file_dia (getvar "filedia"))
(setvar "filedia" 0)
(if (not (findfile "geomcal.arx"))
(prompt "\n Not found 'geomcal.arx' and '_cal command will be not to
work.")
(progn
;(command "appload" "C:\Program Files\ACAD2000\SUPPORT\geomcal.arx")
(command "_arx" "Load" "geomcal.arx")
(setvar "filedia" file_dia)
(princ)
;;;;;; _offset+'cal ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun C:offcal ( / Distanc)
(Load_cal)
(command "_offset")
(setq Distanc (cal))
(command Distanc)
(princ)
Smeghead ÀÌ(°¡) <[email protected]> ¸Þ½ÃÁö¿¡¼­
ÀÛ¼ºÇÏ¿´½À´Ï´Ù...
>Hello Everyone,
calculator.
>(setq pt5 (c:cal
>this
>error;
>acad2000.lsp
>already
>Thanks
>Randy
Message 4 of 11
Middle of two end points (mee). To find the center of a rectangle and place
a hole of proper size based on rectangle width and height. I did notice a
middle point of a line routine in the tutorial , utilities.lsp. I'll give it
a try, thanks.
Eugene N. Kilmer wrote in message <[email protected]>...
>Mr. Smeghead,
rich
>trying to do.
>Eugene N. Kilmer
>Owner/Mag Drafting
Message 5 of 11
There are many ways to avoid this crash. The quick and dirty woul be:
(arxload "c:/program files/ACAD2000/geomcal.arx" 1)
More proper would be checking, if c:cal is already loaded:
(if (/= (type c:cal) 'EXRXSUBR)
(progn
(setq res (arxload "c:/program files/ACAD2000/geomcal.arx" 1))
(if (= res 1)
(prompt "\nCouldn't load calculator arx")
Alex Januszkiewicz
Intelcad Systems and 911 DWG Recovery Services
*Check out our DWF => DWG converter*
** New free ObjectARX downloads coming soon**
Smeghead wrote in message
news:[email protected]...
> Hello Everyone,
calculator.
> (setq pt5 (c:cal
> this
> error;
> acad2000.lsp
> already
> Thanks
> Randy
Message 6 of 11
Hi "Smeghead",
I have nothing to contribute to the issue you raise, other than the fun of
saying "Hi Smeghead" which is your chosen newsgroup name, but which is
generally thought of as a rude insult, at least in the UK, and perhaps in
the USA, where we watch Red Dwarf and other British comedies rich in "smeg"
connotations.
Mark McDonough
[email protected]
Smeghead wrote in message <[email protected]>...
>Hello Everyone,
calculator.
>(setq pt5 (c:cal
>this
>error;
>acad2000.lsp
>already
>Thanks
>Randy
Message 7 of 11
"Smeghead",
You don't need to use the Geometry Calculator for such a simple AutoLISP
Calc:
(setq p3 (polar p1 (angle p1 p2) (/ (distance p1 p2) 2)))
OR:
(setq p3 (MapCar '(Lambda (x1 x2) (/ (+ x1 x2) 2)) p1 p2))
Phillip Kenewell
CAD Systems Technician
Air Gage Company
[email protected]
> Not < a Member of the AutoDESK
Discussion Forum Moderator Program
> Hello Everyone,
calculator.
> (setq pt5 (c:cal
> this
> error;
> acad2000.lsp
> already
> Thanks
> Randy
Message 8 of 11
Would this code be more efficient?
(if (not (member "geomcal.arx" (arx)))
(arxload "c:/program files/ACAD2000/geomcal.arx" "Couldn't load calculator
arx")
Alex Januszkiewicz wrote in message
> (progn
> (if (= res 1)
> Alex Januszkiewicz
>> Hello Everyone,
>calculator.
>> (setq pt5 (c:cal
>> this
>> error;
>> acad2000.lsp
>> already
>> Thanks
>> Randy
Message 9 of 11
Mark McDonough wrote in message
> Hi "Smeghead",
> ...other than the fun of
> the USA, where we watch Red Dwarf ...
i'm (being a transplanted Texican) unfamiliar with the term "smeg..."
_except_ as used on Red Dwarf, which i enjoy at least as much as
HitchHiker's Guide to the Universe; while we're drifting, i wonder if any of
our Russian readers can affirm whether the composer Moussorgsky's name has
the same general connotation as smeghead?
[a rumor i heard, and no offense intended -- he's one of my favorites, too.]
randy benson (in arabic, randy son-of-a-son).
Message 10 of 11
You guys fixed me up, thanks. I see that I don't need the calculator but I
was so used to using 'cal ; mee that thats the only way I could think.
Randy
Message 11 of 11
It probably would, but it would not print the message unless it's the last
statement in the lisp file.
I would say, it's rather a matter of preference then efficiency, as you
would need to load 10000 files to catch measurable difference (say 1 sec?)
I usually concentrate my efforts in areas, where significant improvements
can be achieved by proper coding (iterations would be one of them). I can
make my first shot a bit tighter:
(if (= 1 (arxload "c:/program files/ACAD2000/geomcal.arx" 1))
I admit: I'm careless about efficiency of these particular code fragments,
as long as they properly load the program and trap possible error.
Alex Januszkiewicz
Mark E. Fretty wrote in message
calculator
> arx")
> > (progn
> > (if (= res 1)
> > Alex Januszkiewicz
> >> Hello Everyone,
> >calculator.
> >> (setq pt5 (c:cal
get
> >> this
> >> error;
> >> acad2000.lsp
its
> >> already
> >> Thanks
> >> Randy
