Having trouble selecting the title block
angelinabrown0123
Message 1 of 27
angelinabrown0123
please help,
I am trying to print by selecting the title block, my block name is "MyBox" but it is not getting selected, please fix this code in selecting the block.
Replies (26)
Message 2 of 27
ronjonp
It's because your titleblock is dynamic and the actual name is '*U9'.
Change your filter to this:
(setq ss (ssget '((0 . "INSERT") (2 . "MyBox,`*U*"))))
Message 3 of 27
angelinabrown0123
That worked great, Thank you very much!
Message 4 of 27
ronjonp
Glad to help! 🙂
Message 5 of 27
calderg1000
Regards @angelinabrown0123
If what you want is to select the block, with this line of code you can generically select any block. In your case you have a block with attributes; that will change its name when the attributes change.
(setq s (ssget'((0 . "insert"))))
 To get your name:
(vla-get-name(vlax-ename->vla-object(ssname s 0)))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 6 of 27
Sea-Haven
We always had our title blocks at 0,0 so you can look for a block using the ssget "F" or "CP" which use co-ordinates to search for objects, this also works for a pt.
(setvar 'osmode 0) ; turn off snap or use a zoom in
 (setq ss (ssget (list 0 0)))
<Selection set: 000000006F0C67F0>
(entget (ssname ss 0))
((-1 . <Entity name: 3d7debe0>) (0 . "INSERT") (5 . "102B6")
Message 7 of 27
Kent1Cooper
@Sea-Haven wrote:
We always had our title blocks at 0,0 so you can look for a block using the ssget "F" or "CP" ....
That's fine if there's some drawn element at the insertion point, such as a corner of border lines in the Block.  But if 0,0 is the insertion point and the corner of the sheet, and the border/outline itself is inset from there, that won't work any more than picking manually at 0,0 would, with nothing there to pick on.
But in that case, you could get it with filtering for a Block with that as its insertion point:
(setq ss (ssget '((0 . "INSERT") (10 0.0 0.0 0.0))))
or even, if there would not be anything else drawn with a 10-code entry at that location other than the Block [such as the start of a Line], merely:
(setq ss (ssget '((10 0.0 0.0 0.0))))
Kent Cooper, AIA
Message 8 of 27
Sea-Haven
We had a rule at my work move the title block and get your butt kicked. yeah had a move it back to 0,0 lisp, multiple users.
Only problem with dxf 10 is that ssget still asks for a selection where as (ssget pt) works without user input yes has that draw back of possible miss or multiple chosen, using filter helps
(entget (ssname (ssget (list 0.0 0.0 0.0)(list (cons 0 "INSERT"))) 0))
Message 9 of 27
angelinabrown0123
The problem of selecting blocks has been solved by @ronjonp, but I am facing another problem with lisp, the enclosing lisp does not print with some blocks nothing is showing in pdf.
Message 10 of 27
pbejse
..., the enclosing lisp does not print with some blocks nothing is showing in pdf.
Check your UCS...
or you can do this
"No"
"Window"
(trans llpt 0 1)
(trans urpt 0 1)
"Fit"
"Center"
"yes"
HTH
Message 11 of 27
Kent1Cooper
If there won't be any other Block(s) or Xref(s) inserted at that point, you can get it without User input:
(setq ss (ssget "_X" '((10 0.0 0.0 0.0))))
and that could be further constrained to only the current space, only Block/Xref [in case there could be something like a Line start point or Text insertion point or Circle center there], etc.
Kent Cooper, AIA
Message 12 of 27
angelinabrown0123
@pbejse ,
Thanks for the code, I also tested on some other drawing with new code but it still doesn't generate PDF properly.
Message 13 of 27
pbejse
Quick question:
Why is the UCS rotated ? Are you planning to select mulitple titleblocks? [ that is what the lsp file was intending to do from the looks of it  . repeat / vl-sort / foreach ] ... you will have an issue with the pdf name(s).
Message 14 of 27
calderg1000
Your code works fine but in the WCS, but for some reason all your files are in the UCS, but for some reason the provided transformation is not working.
It would not be advisable to work the plots from the WCS and avoid problems. Because its blocks are rotated...?
it seems to apply Get-boundingbox to obtain the limit points, in this case it is not the most appropriate
Carlos Calderon G
Message 15 of 27
Sea-Haven
This has been looked at before for me never plot in model space always a layout where the mview can be twisted to match a UCS and scale, would be worth looking into.
A example 10km road mulitple sheets and road approx horizontal on all sheets. Just multiple UCS.
I went to a  layout of your dwg. The title is true size so its 841 long. It took like 2 minutes at most
Just drew a line for angle of title block in Model space
Went to layout1 inserted MYBOX scale 1 0,0 etc
Did Mview inside mybox
Dbl click into mspace then zoom extents
Can see the line I made did UCS OB pick line, then Plan, then zoom e
Now set plot scale and erase temporary line for UCS.
Lock viewport so no false zooms
All done
Last question why is block dynamic and not a normal block ?
Message 16 of 27
pbejse
My query regarding multiple blocks has been left unanswered, so here's a version with one selection.
(defun c:SpA1 (/ UCS2WCSMatrix WCS2UCSMatrix ucs-bbox ss file hnd pts)
;; Doug C. Broad, Jr.
;; can be used with vla-transformby to
;; transform objects from the UCS to the WCS
(defun UCS2WCSMatrix ()
  (vlax-tmatrix
    (append
      (mapcar
	'(lambda (vector origin)
	   (append (trans vector 1 0 t) (list origin))
	(list '(1 0 0) '(0 1 0) '(0 0 1))
	(trans '(0 0 0) 0 1)
      (list '(0 0 0 1))
;; transform objects from the WCS to the UCS
(defun WCS2UCSMatrix ()
  (vlax-tmatrix
    (append
      (mapcar
	   (append (trans vector 0 1 t) (list origin))
	(trans '(0 0 0) 1 0)
      (list '(0 0 0 1))
;; UCS-BBOX (gile)
;; Returns the UCS coordinates of the object bounding box about UCS
;; Argument
;; obj : a graphical object (ename or vla-object)
;; Return
;; a list of left lower point and right upper point UCS coordinates
(defun ucs-bbox	(obj / space bb minpoint maxpoint line lst)
  (vl-load-com)
  (and (= (type obj) 'ENAME)
       (setq obj (vlax-ename->vla-object obj))
  (vla-TransformBy obj (UCS2WCSMatrix))
  (setq bb (vla-getboundingbox obj 'minpoint 'maxpoint))
  (vla-TransformBy obj (WCS2UCSMatrix))
  (list
    (vlax-safearray->list minpoint)
    (vlax-safearray->list maxpoint)
(vl-load-com)
	(if (setq ss (ssget "_+.:S:E" '((0 . "INSERT") (2 . "MyBox,`*U*"))))
        (progn
                (setq hnd (ssname ss 0)
                     file (strcat (getvar 'DWGPREFIX)
                                   (substr (setq dwg (getvar 'DWGNAME)) 1 (- (strlen dwg) 4))
                                   ".pdf"
                (if (findfile file)
                    (vl-file-delete file)
	       (setq pts (ucs-bbox (vlax-ename->vla-object hnd)))
               (command "-plot"
                         "yes"
                         "Model"
                         "DWG TO PDF.PC3"
                         "ISO A1 (594.00 x 841.00 MM)"
                         "Millimeters"
                         "Landscape"
                         "No"
                         "Window"
                         (Car pts)
                         (Cadr pts)
                         "Fit"
                         "Center"
                         "yes"
                         "acad.ctb"
                         "yes"
                         "No"
                        file
                        "Yes"
                        "Yes"
    (princ)
HTH
Message 17 of 27
angelinabrown0123
Wow. Its like magic! Thank you @pbejse. Way above my pay grade.
Many thanks for taking an interest in my project.
Message 18 of 27
angelinabrown0123
Hi @pbejse ,
Please help me one more time if possible, I have to select title block automatically, I tried to little change the code for automatically select the title block but it is not visible in printing all the objects.
(if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "MyBox,`*U*"))))
thank you in advanced
Message 19 of 27
pbejse
Going back to my previous query, will there be more than one "MyBox" block per drawing? Very important to know this seemingly minor detail @angelinabrown0123
Message 20 of 27
angelinabrown0123
@pbejse
Currently there is only one title block in the drawing. But in future there may be multiple title block in the single drawing.
