Having a problem with a LISP script
PilonWorks
PilonWorks
All,
When I run this script:
(defun C:ALLFLAT ()
(ssget)
(command "move" "p" "" '(0 0 0) '(0 0 1e99) "move" "p" "" '(0 0 0) '(0 0 -1e99))
It is only supposed to move all selected objects in the Z axis. This command is moving selected items in the X and Y axis as well. It is only behaving this way for some users. I have done some VBA for autocad scripting but LISP is a bit outside what I know. Could you at least get me pointed in the right direction? Thanks in advance!
ВeekeeCZ
You should have OSNAPs OFF before you run the code. That could make the difference.
Edit: @cadffm  too slooow, again. Sorry!
cadffm
VBA or LISP, MOVE is a native command.
I guess you have objects near to 0,0,0
and your running object snaps are ON.
You should add (setvar "osnapcoord" 1) as second line
or add "_none" in front of all coordinates.
Quick test: set osnaps off [F3], start the lisp again in this dwg.
Sebastian
PilonWorks
Yep, having OSNAP turned off fixed the issue, the code is now:
(defun C:FLATFLAT ()
(ssget)
(command "move" "p" "" "_none" '(0 0 0) "_none" '(0 0 1e99) "move" "p" "" "_none" '(0 0 0) "_none" '(0 0 -1e99))
Thanks for the help and this has solved a headache. You guys rock!
