Hatch merge/split,
Hatch merge/split,
JamaL9722060
Message 1 of 25
Hatch merge/split,
JamaL9722060
Hatch merge/split,
I got a lisp file that does merge two existing hatching into one.
  • But the issue is that in case of overlapping hatches the code does merge the hatches BUT it subtracts the overlapping area of the two hatches!
What I wanted is to merge them and to keep the overlapping area as a part of the result
  • I couldn’t find any lisp file that split an existing hatch based on multiple existing lines
Thank you
Best
Jamal
Jamal Numan
Replies (24)
Message 21 of 25
hmsilva
You're welcome, Jamal
It is just a demo...
Henrique
Message 22 of 25
Automohan
Hello Sir; I try your above code on my dwg but it not works for me, pls. help me as shown in the Image I need to trim the hatch inside polyline many thanks Automohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Message 23 of 25
JamaL9722060
I couldn’t figure out why the HatchSplit.lsp file fails to split the hatch in the attached file.
What could be the issue here?
The dwg and lisp files are attached
Jamal Numan
Message 24 of 25
diagodose2009
Why, after changing the color/s of multiple hatches, the function mergeHatch does not work?
Command: q2
Select objects: Specify opposite corner: 7 found
ColorCalc[1.yes/0.no]=1
Current active settings:  Color Layer Ltype Ltscale Lineweight Thickness
PlotStyle Dim Text Hatch Polyline Viewport Table Material Shadow display
Multileader
Point-of-Areas.dic?
EndT
Message 25 of 25
yasmindomanais
Community Visitor
Community Visitor
This is really a big help. Thank you so much for this .lsp
