Hatch entities
Hatch entities
Hatch entities
Hi all, I'm working with entities, specifically with hatch entities.
I want to know if I can change the hatch transparency. I know this codes:
2 Hatch pattern name
70 Solid fill flag (solid fill = 1; pattern fill = 0)
52 Hatch pattern angle (pattern fill only)
41 Hatch pattern scale or spacing (pattern fill only)
But none about transparency
Thanks for your time!
Not sure but there is a 440 with transparency I set to 50 white  but  (440 . 33554559) so some form of rgb maybe.
32-bit integer value. When used for True Color, the transparency value, still no idea about how to work out number.
You we're right @Anonymous ! thank you so much!
