handling duplicate attributes in block
Patrick.De.Neef
Patrick.De.Neef
Hello all
I "inherited a large number of autocad drawings where the title blocks have a lot of duplicate attributes (see block_attributes.png in zip file)
I thought I could get around the problem (replacing/renaming the duplicates) by using also the prompt which (for some reason) is unique but trying to extract also the tag name and the value results in returning the same twice for the duplicates or giving double output
I based all my attempts on two lsp files I found (one from Lee Mac and another from Kevin, thank you both)
I included the original lsp's and the output in the zip file
Hope someone here can help me out
Thanks & Regards
Patrick
marko_ribar
See if this post can help you...
http://www.theswamp.org/index.php?topic=55172.msg594767#msg594767
Marko Ribar, d.i.a. (graduated engineer of architecture)
ВeekeeCZ
Not sure what your goal is, but this lists all atts/attd
def-prompt def-tag ref-tag ref-value
(defun c:ListAtts (/ er ed d rl dl )
  (if (and (setq er (car (entsel "Select a block: ")))
	   (setq ed (tblobjname "BLOCK" (cdr (assoc 2 (entget er))))))
    (progn
      (while (setq ed (entnext ed))
	(if (= "ATTDEF" (cdr (assoc 0 (setq d (entget ed)))))
	  (setq dl (cons (list (cdr (assoc 3 d)) (cdr (assoc 2 d))) dl))))
      (while (and (setq er (entnext er))
		  (= "ATTRIB" (cdr (assoc 0 (setq d (entget er))))))
	(setq rl (cons (list (cdr (assoc 2 d)) (cdr (assoc 1 d))) rl)))))
  (foreach l (reverse (mapcar 'append dl rl))
    (princ "\n") (print l))
  (princ)
pbejse
Replace this from GetAttributeTagPromptValue function [ at test_leemac.lsp ]
(mapcar
    (function
      (lambda ( attrib )
        (append (assoc (vla-get-TagString attrib) lst) (list (vla-get-TextString attrib)))
    (vlax-invoke block 'GetAttributes)
With this
(mapcar
    (function
      (lambda ( attrib values)
       (list (cAR attrib)(cadr attrib)(Vla-get-textstring values))
    (reverse lst)(vlax-invoke block 'GetAttributes))
HTH
Patrick.De.Neef
Hello pbejse
Thank You Very Much !!!
Awsome, this is exactly what I need, you saved me hours of work
Best Regards
Patrick
