Grips, grip-stretch and reactors...
JoistDetailer
Message 1 of 10
JoistDetailer
I have reactors that update mtext based on the size of a rectangle after it's been modified via grip_stretch.  Everything is working well so far.  Now, I'm trying to refine it so the user can't change the rectangle by stretching corners, because the rectangle must remain a rectangle.
I have been successful in identifying a corner grip stretch in my "vlr-CommandWillstart" reactor callback.  However, I have not been successful in cancelling the stretch.  I'm thinking that it's becasue the stretch has not actually *started* yet, so there is nothing to cancel?
I've tried something like this (from other forums - hat tip to Lee Mac), but it didn't work:
(vl-catch-all-apply 'vlax-invoke (list (vlax-create-object "WScript.Shell")'sendkeys "{ESC}"))
Here are my options in order of preference:
1) When rectangle is selected, only show midpoint grips (or disable corner grips).  This would be the cleanest way to do it (only present the user with "permitted" actions), but I don't know if this is possible or not.
2) If "1" is not possible, if corner grip is being stretched, cancel the grip-stretch.
3) Last resort, undo the corner grip-stretch (I already know how to do this).
Thanks in advance for any help in getting me pointed in the right direction!!
Replies (9)
Message 2 of 10
Moshe-A
@JoistDetailer  hi,
take a look  >> at this thread <<
i test it and it works.
i would add a descriptive message to users so they know what is going on, otherwise they would think something is wrong with autocad.
moshe
moshe
Message 3 of 10
JoistDetailer
That's where I got code snipped that I gave the h/t to Lee Mac for.  I'll study it again, maybe I overlooked something.
...and, yes, I already have a message popping up to let the user know that stretching corners is not permitted.
Thanks for the response...
Message 4 of 10
JoistDetailer
...and yes, I *did* overlook something!
(vl-load-com)!!  Smiley Embarassed
However, I'd still like to see if my "preferred" method of NOT showing the corner grips is a possibility.
Message 5 of 10
JoistDetailer
Message 6 of 10
Moshe-A
As far as i know (hope i'm not mistaken) you do not have control on grips except for turning them on/off (yes also their color and side) but i think as the user picks an object the grips are popup at the same time the reactor is activated.
Message 7 of 10
Kent1Cooper
Use a Block instead of a [Polyline] rectangle?  Depending on how universal the need is, you could even potentially re-define the RECTANG command to make a Block instead.  I'm not up on dynamic Blocks, but I expect one could be built that would allow adjustments without going through the scale entries in Properties, but would always remain rectangular.
Kent Cooper, AIA
Message 8 of 10
JoistDetailer
Kent,
I may consider that, but the "rectangle only" may be a short-term limitation.  But, yes, I am looking into dynamic blocks for other purposes and using it for this purpose is an interesting idea.  It could potentially clean up my reactors significantly.
Thanks!
Message 9 of 10
JoistDetailer
Moshe-A,
I know that the grips are displayed before the CommandWillStart reactor fires.  I don't think there is a reactor for a "object selected" event, but I may be wrong.
Looks like the best I can do is my "option #2", which I've implemented and am mostly satisfied with.
However, I'm intrigued with your reference to controlling a grip's "color and side"...can you elaborate, please?
Message 10 of 10
Moshe-A
@JoistDetailer ,
i meant that you can change the color and size of the grips by sys vars:
GRIPS
GRIPSIZE
GRIPCOLOR
moshe
