Grab objects in a selection set resulting from vla-explode
rajeshpatnaik2001
rajeshpatnaik2001
(ssget "_P") selects the objects resulting from (command "._Explode" entity).
But it is not selecting objects resulting from (vla-explode obj).
(ssget "_P") returns nil.
How to grab all the objects in a selection set resulting from (vla-explode obj)?
Kent1Cooper
The typical way would be to mark the last object in the drawing as a variable before doing the exploding, then after, march through with (entnext) as long as there continues to be a next entity, and add those things to a selection set.
Something like [untested]:
(setq
  elast (entlast)
  ss (ssadd); initially empty selection set
(vla-explode obj)
(while (setq elast (entnext elast))
  (ssadd elast ss)
Kent Cooper, AIA
rajeshpatnaik2001
Thanks @ Kent Cooper 🙂
ВeekeeCZ
Since the vla-explode method actually returns an array of exploded objects, you could use that.
Not saying it's simpler...
(defun c:Test ( / s)
  (setq s (ssadd))
  (mapcar '(lambda (e) (ssadd (vlax-vla-object->ename e) s))
	  (vlax-safearray->list (vlax-variant-value (vla-explode (vlax-ename->vla-object (car (entsel)))))))
  (sssetfirst nil s))
