Message 1 of 55
Hi there!
I usually face this situation where I need to connect two lines with a curve and I don't like the blend command because it is not a polyline and I don't like to transform a spline to a polyline because it is not accurate and simple.
The best would be to create two curves, connected to each other and the two lines and that are tangent to each other and to the lines.
Do you think it is possible to create a Lisp for that? I couldn't even imagine how to start. Thank you so much
