Getting the Font file info from a selected piece of xref text
nick.seman
nick.seman
Hello:
I am able to extract the Text Style Name from a selected piece of text in an xref via:
(setq textStyleName (if (vlax-property-available-p textObj 'StyleName) (vla-get-StyleName textObj) ""))
however I am unable to figure out how to get the font file information from the text style.
Pointing me in the correct direction would be greatly appreciated!
Thanks;
Nick
paullimapa
how's about:
(cdr(assoc 3(tblsearch "STYLE" textStyleName)))
Paul Li
IT Specialist
@The Office
Kent1Cooper
Or, directly by pick of the nested Text/Mtext object, without needing to extract the Style name first if you don't really need to know that:
(cdr (assoc 3 (tblsearch "STYLE" (cdr (assoc 7 (entget (car (nentsel))))))))
But be aware, of course, that for Mtext, that is the font assigned to the Style assigned to the overall Mtext object, referred to in the DXF reference as the "Primary font file name."  There is the possibility of a font override in internal formatting, so that may not be the font you see.
Kent Cooper, AIA
