Getting polyline info when ucs is rotated
Hi all,
I am not ashamed to admit this is well outside my understanding and am begging for help...
We draw polylines in model space and some users rotate their UCS (for viewport purposes) and all of a sudden, the polyline no longer consists of linesegments and the pick point becomes the endpoint of the polyline. I have found some code that has helped me sort of understand, but although the line works rotating correctly, it still goes to the end of the line.
Is there anyone here who can help me (not necessarily by giving me the answer) with the following things:
1. Why when the ucs is rotated around the Z axis, does the pick point not work and
2. Why does the polyline suddenly not consist of the same line segments it did when the ucs is not rotated?
My code is below (feel free to criticise):
   Public Sub GetRot(ByVal sHType As String)
        Dim oid As ObjectId
        Dim iRot As Double
        Dim pickPt As Point3d
        Dim sp As Point2d
        Dim ep As Point2d
        Dim fine As Boolean = True
        Dim isBlk As Boolean = False
        Dim locked As New ObjectIdCollection()
        Dim acLine As New Line
        Dim pKeyOpts As PromptKeywordOptions = New PromptKeywordOptions("")
        pKeyOpts.Message = vbLf & "Up (U) or Down (D) ? "
        pKeyOpts.Keywords.Add("U")
        pKeyOpts.Keywords.Add("D")
        pKeyOpts.Keywords.Default = "U"
        pKeyOpts.AllowNone = False
        Dim pKO2 As PromptKeywordOptions = New PromptKeywordOptions("")
        pKO2.Message = vbLf & "Invert (Y/N) ? "
        pKO2.Keywords.Add("Y")
        pKO2.Keywords.Add("N")
        pKO2.Keywords.Default = "N"
        pKO2.AllowNone = False
        Using doc.LockDocument()
            Dim pno As PromptNestedEntityOptions = New PromptNestedEntityOptions("" & vbLf & "Select Line ")
            Dim nres As PromptNestedEntityResult = ed.GetNestedEntity(pno)
            If (nres.Status <> PromptStatus.OK) Then
                ed.WriteMessage("" & vbLf & "Selection failed")
                Return
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                ' try to unlock layers
                Dim lt As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
                For Each ltId As ObjectId In lt
                    If ltId.IsValid AndAlso ltId.IsResident AndAlso Not ltId.IsErased Then
                        Dim ltr As LayerTableRecord = DirectCast(tr.GetObject(ltId, OpenMode.ForRead), LayerTableRecord)
                        If ltr.IsLocked Then
                            locked.Add(ltId)
                            ltr.UpgradeOpen()
                            ltr.IsLocked = False
                Next
                oid = nres.ObjectId
                oEntHook = CType(tr.GetObject(oid, OpenMode.ForWrite), Entity)
                Dim ctnIds() As ObjectId = nres.GetContainers()
                If Not ctnIds.Length = 0 Then
                    If Not UCase(oEntHook.BlockName).Equals("*MODEL_SPACE") Then
                        Dim br As BlockReference = DirectCast(tr.GetObject(ctnIds(0), OpenMode.ForRead), BlockReference)
                        iRot = br.Rotation
                        isBlk = True
                Try
                    Dim UCS As CoordinateSystem3d = ed.CurrentUserCoordinateSystem.CoordinateSystem3d
                    Dim OcsPlane As Plane = New Plane(Point3d.Origin, UCS.Zaxis)
                    Dim OCS As CoordinateSystem3d = Matrix3d.PlaneToWorld(OcsPlane).CoordinateSystem3d
                    Dim ucsRotation As Double = OCS.Xaxis.GetAngleTo(UCS.Xaxis)
                    Dim vec1 As Vector3d
                    Dim aa As Double
                    Select Case isBlk
                        Case False
                            Select Case True
                                Case TypeOf oEntHook Is Line
                                    Dim oLine As Line = DirectCast(tr.GetObject(oEntHook.ObjectId, OpenMode.ForRead), Line)
                                    pickPt = oLine.GetClosestPointTo(nres.PickedPoint, False)
                                    vec1 = oLine.StartPoint.GetVectorTo(oLine.EndPoint)
                                    aa = vec1.AngleOnPlane(OcsPlane)
                                    ed.WriteMessage(vbLf & "Aa IS " & aa.ToString)
                                    iRot = aa
                                Case TypeOf oEntHook Is Polyline
                                    Dim pline As Polyline = DirectCast(tr.GetObject(oEntHook.ObjectId, OpenMode.ForRead, False), Polyline)
                                    If pline IsNot Nothing Then
                                        pickPt = pline.GetClosestPointTo(nres.PickedPoint, False)
                                        Dim param As Double = pline.GetParameterAtPoint(pickPt)
                                        Dim index As Integer = CInt(Math.Truncate(param))
                                        Dim stype As SegmentType = pline.GetSegmentType(index)
                                        ed.WriteMessage(stype.ToString)
                                        If stype = SegmentType.Line Then
                                            Dim lineseg As LineSegment2d = pline.GetLineSegment2dAt(index)
                                            ed.WriteMessage(vbLf & index)
                                            sp = lineseg.StartPoint
                                            ep = lineseg.EndPoint
                                            acLine = New Line(New Point3d(sp.X, sp.Y, 0), New Point3d(ep.X, ep.Y, 0))
                                            'iRot = acLine.Angle
                                            vec1 = acLine.StartPoint.GetVectorTo(acLine.EndPoint)
                                            iRot = aa
                                        Else
                                            ed.WriteMessage("Why is it suddenly no longer a lineseg???")
                            End Select
                            ed.WriteMessage(vbLf & "PP = {0}", pickPt.ToString)
                            If iRot > funcGetRads(180) Then
                                iRot -= funcGetRads(180)
                            ElseIf iRot = 0 Then
                                '' I need a function to ask whether it is up or down on a zero line
                                Dim pKeyRes As PromptResult = ed.GetKeywords(pKeyOpts)
                                Select Case UCase(pKeyRes.StringResult)
                                    Case "U"
                                        Select Case sHType
                                            Case "R" : iRot += funcGetRads(180)
                                        End Select
                                    Case "D"
                                        Select Case sHType
                                            Case "L" : iRot += funcGetRads(180)
                                        End Select
                                End Select
                            ElseIf iRot = funcGetRads(180) Then
                                    Case "U"
                                        Select Case sHType
                                            Case "L" : iRot -= funcGetRads(180)
                                        End Select
                                    Case "D"
                                        Select Case sHType
                                            Case "R" : iRot -= funcGetRads(180)
                                        End Select
                                End Select
                    End Select
                    iRot -= funcGetRads(90)
                    'End Select
                    ed.WriteMessage(vbLf & "LINE ANGLE IS " & funcGetDegrees(iRot).ToString)
                Catch ex As System.Exception
                    ed.WriteMessage(vbLf & "Error: {0}" & vbLf & "Trace: {1}", ex.Message, ex.StackTrace)
                Finally
                    For Each ltId As ObjectId In locked
                        Dim ltr As LayerTableRecord = DirectCast(tr.GetObject(ltId, OpenMode.ForWrite), LayerTableRecord)
                        ltr.IsLocked = True
                    Next
                    tr.Commit()
                End Try
            End Using
        End Using
        dHRot = iRot
        ptH3d = pickPt
        Return
    End Sub
I am failing to wrap my head around why the rotation of the ucs affects these entities the way it is. What am I doing wrong here? The program works perfectly if the ucs is not rotated.
Thank you all in advance.
natasha.l
Hello @bh
From what I can see & what you have explained to me. It seems the UCS is not being used properly in model space.
"UCS sets the origin and orientation of the current user coordinate system that establishes the XY work plane, horizontal and vertical directions, axes of rotation, and other useful geometric references."
The model space UCS should be left alone, but in Paperspace the view can be changed without affecting the model space UCS.
You should reset the UCS in model space & use the workflow outlined in my video. I really hope this helps & is the issue.
Updated, sorry about the Screencast not posting. I have the link to the >Video <.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
s.borello
If it works fine when you don't rotate USC then why rotate it?  What's the benefit?  Not trying to be an a** just want to try to understand your workflow.
Hi all, I am with you 100%, there should be no need to rotate the ucs, but unfortunately I work with some "Engineers" and you know what that is like, you can lead them to CAD but you will never make a draftsman of them. My level of AutoCAD is the same in that I always rotate the ucs within the viewport, but this is an issue that is just popping up due to a single user who it seems cannot be taught. I had hoped there was a way to account for it, but it would appear not. Thank you anyway.
