Getting fatal error access violation when using WblockCloneObjects to clone blocks from another drawing database.
(ok so I posted this in the wrong forum by mistake. Should be in .NET forum. Don't know how to delete question. Posted the same question in >NET forum.)
I've created a c# .NET plugin for autocad which adds a command. I have has a macro in an excel file which starts autocad and runs the plugin command which gets the input through excel file and then creates what is required.
The plugin needs to import blocks from another drawing and I'm using WblockCloneObjects to do this.
I've used the same import code till now without any issues.
When I run the macro through excel I'm randomly getting fatal error access violation error with autocad crashing at WblockCloneObjects line. This happens randomly when starting through excel macro. (Happened only once in debug mode, can't replicate the error again in debug mode.)
I'm using AutoCAD mechanical 2020.
In excel, I've reference AutoCAD 2019 Type Library(can't find for 2020) and AutoCAD Mechanical 2020 Type Library.
Can any one please help?
I'm attaching the error details, the import code and application starting code below.
Error shown from the dump file:
Call stack:
Full first line in call stack:
> Acdbmgd.dll!Autodesk.AutoCAD.DatabaseServices.Database.WblockCloneObjects(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection identifiers, Autodesk.AutoCAD.DatabaseServices.ObjectId id, Autodesk.AutoCAD.DatabaseServices.IdMapping mapping, Autodesk.AutoCAD.DatabaseServices.DuplicateRecordCloning cloning, bool deferTranslation) Line 6207 C#
Import Method being used:
/// <summary>
/// Checks if given block names exist in given block table and imports all blocks from given drawng if not.
/// </summary>
/// <param name="blockNamesToCheck">Array of block names to check.</param>
/// <param name="drawingPaths">import location of the blocks.</param>
public static void ImportBlocks(string[] blockNamesToCheck, string sourceFileName)
DocumentCollection dm = Application.DocumentManager;
Editor ed = dm.MdiActiveDocument.Editor;
Database destDb = dm.MdiActiveDocument.Database;
Database sourceDb = new Database(false, true);
//string sourceFileName;
if (!ShouldImport(destDb, blockNamesToCheck))
return;
try
// Read the DWG into a side database
sourceDb.ReadDwgFile(sourceFileName, FileOpenMode.OpenForReadAndAllShare, false, null);
// Create a variable to store the list of block identifiers
ObjectIdCollection blockIds = new ObjectIdCollection();
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = sourceDb.TransactionManager;
using (Transaction myT = tm.StartTransaction())
// Open the block table
BlockTable bt = (BlockTable)tm.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, false);
// Check each block in the block table
foreach (ObjectId btrId in bt)
BlockTableRecord btr = (BlockTableRecord)tm.GetObject(btrId, OpenMode.ForRead, false);
// Only add named & non-layout blocks to the copy list
if (!btr.IsAnonymous && !btr.IsLayout) blockIds.Add(btrId);
btr.Dispose();
// Copy blocks from source to destination database
IdMapping mapping = new IdMapping();
sourceDb.WblockCloneObjects(blockIds, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
// ed.WriteMessage("\nCopied " + blockIds.Count.ToString() + " block definitions from " + sourceFileName + " to the current drawing.");
ed.WriteMessage("Blocks imported.");
catch (Autodesk.AutoCAD.Runtime.Exception ex)
ed.WriteMessage("\nError during copy: " + ex.Message);
throw new Exception(ex.Message);
sourceDb.Dispose();
VBA code in Excel Macro:
Dim ACAD As AcadApplication
Dim NewFile As Object
Dim MyAcadPath As String
Dim bReadOnly As Boolean
On Error Resume Next
Set ACAD = GetObject(, "autocad.Application")
If (Err <> 0) Then
Err.Clear
Set ACAD = CreateObject("autocad.Application")
If (Err <> 0) Then
MsgBox "Could Not Load AutoCAD!", vbExclamation
End
ACAD.Visible = True
MyAcadPath = "C:\Autodesk\Drawing.dwg"
bReadOnly = True
Set NewFile = ACAD.Documents.Open(MyAcadPath, bReadOnly)
Call CreateInputString
NewFile.SendCommand cmd
References being used in excel macro
I would really appreciate any help.
Thanks in advance!!!
