Getting dwg directory
DGRL
Advisor Advisor
DGRL
I already have my LSP working properly
Reason why it did not work correctly is because I forgot to add an double \\ LOL
Dear forum members
Currently working on a lisp file and I need the dwg directory in a variable
Dwgprefix will give me an path but woth double \\
"D:\\P3D TEST\\TEST PROJECT\\Orthos\\DWGs\\"
Does anyone know how to remove an single \ in the path? and how top change them into / ( windows standard )
I need the path to copy and saveas an dwg file and I don't like to hard code the dwg path in my lsp
An different approach is also welcome
Best regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
DannyNL
This is one possibility.
(setq path (vl-string-right-trim "\\"(getvar "DWGPREFIX")))
(while
   (vl-string-search "\\" path)
   (setq path (vl-string-subst "/" "\\" path))
