getpoint, number, 2.78461e+06
jbarringer
jbarringer
I'm using getpoint to pick a point sometime it returns a number like 2.78461e+06 sometimes it works in the code below and sometimes it does not.
(vlax-invoke-method align 'StationOffset (car pt) (cadr pt) 'sta 'off)
I would like to know why and how to fix this.
(rtos (car pt)) = "2784605.88"
ВeekeeCZ
 The result of (rtos) depends on current UNIT setting - especially LUNITS and LUPREC sysvars
You can override the current setting by specifying them in (rtos)
(rtos number [mode [precision]])
So in your example, use
(rtos (car pt) 2 2) = "2784605.88"
Look into HELP  for more details.
jbarringer
Sorry for the confusion my question is not with the "RTOS"  it is:
I'm using getpoint to pick a point sometime it returns a number like 2.78461e+06 (car pt) sometimes it works in the code below and sometimes it does not.
ВeekeeCZ
Well, then it's more C3D related issue, better post it HERE
Kent1Cooper
@jbarringer wrote:
.... sometime it returns a number like 2.78461e+06 ....
Those are equivalent [to different rounding levels].  The first is scientific notation -- the e is for exponent -- and means "2.78461 x 10 to the 6th power."  Why it sometimes "reports" in that format I don't know, but either is the same information, and should not need fixing.
Kent Cooper, AIA
