getpoint modification
Hi Team,
Could any one help me on the below lisp, here in the step i want to specify n number of points in this  "(setq p1 (getpoint "\nSpecify the point A: "))".
(defun c:pcline ( / en ex e1 e2 el p1 q1 p2 q2 pe ps la)
(if (and (setq *c2p-en* (cond ((car (entsel (strcat "\nSelect axis polyline " (if *c2p-en* " <last>" ": ")))))
(*c2p-en*)))
(= "LWPOLYLINE" (cdr (assoc 0 (entget *c2p-en*))))
(setq p1 (trans p1 1 0))
(setq q1 (vlax-curve-getClosestPointTo *c2p-en* p1))
(setq p2 (getpoint "\nSpecify the point B: "))
(setq p2 (trans p2 1 0))
(setq q2 (vlax-curve-getClosestPointTo *c2p-en* p2))
(setq ps (vlax-curve-getStartPoint *c2p-en*))
(setq pe (vlax-curve-getEndPoint *c2p-en*))
(progn
(setq la "test")
(command ".-LAYER" "_New" la "_Color" 2 la "")
(setq en (entmakex (append (entget *c2p-en*)
(list (cons 8 la)))))
(setq el (entlast))
(and (not (equal q1 pe 1e-6))
(not (equal q1 ps 1e-6))
(vl-cmdf "_.BREAK" en "_none" (trans q1 0 1) "_none" (trans q1 0 1))
(not (equal el (entlast)))
(setq ex (entlast))
(if (equal q2 (vlax-curve-getClosestPointTo en q2) 1e-6)
(if ex (entdel ex))
(progn
(entdel en)
(setq en ex)))
(setq ex nil
el (entlast))
(and (not (equal q2 pe 1e-6))
(not (equal q2 ps 1e-6))
(vl-cmdf "_.BREAK" en "_none" (trans q2 0 1) "_none" (trans q2 0 1))
(setq ex (entlast))
(if (and (or (equal q1 (vlax-curve-getStartPoint en) 1e-6)
(equal q1 (vlax-curve-getEndPoint en) 1e-6))
(or (equal q2 (vlax-curve-getStartPoint en) 1e-6)
(equal q2 (vlax-curve-getEndPoint en) 1e-6)))
(if ex (entdel ex))
(progn
(entdel en)
(setq en ex)))
(setq e1 (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 q1) (cons 8 la)))
e2 (entmakex (list (cons 0 "LINE") (cons 10 p2) (cons 11 q2) (cons 8 la))))
(initcommandversion)
(command "_.JOIN" e1 en e2 "")
(princ)
Thank you!
john.uhden
I don't see how it fits with your program, but do you mean like 10 points (p1 through p10 and "A" through "J") depending on the value of n?
John F. Uhden
Sorry John,
It's was duplicated, I got solution from Beekee.
Thank you.
